Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:03 am)
Does it work on Windows computers that only have IE6? If my computer can't run IE7 will I be unable able to use Poser 8 on it?
I'm using it on a fully updated XP SP3 machine with IE 6 and it seems to work fine. I haven't yet gotten it to work with IE 6 running under Wine, so it may require an update to IE6..
"Oh - the manual says that? I have never read the manual - this must be why."hmmm I am puzzled now because I had the same problem...I installed and no libraries, just a blank box where the libraries should be.
I installed the right version of flash on ie 8 and on firefox... and looked at the folder
file:///C:/Program%20Files/Smith%20Micro/Poser%208/Runtime/ui/Flex/LSMGUI/bin-release/LSMGUI.html#
I can see the runtimes fine....except in poser. I have restarted poser severl times and nothing but it working in the browser. Ideas?
You don't need to turn off Zone Alarm completely. Just open it up (click on teh little Z in the task bar) click on program control on the lefdt hand side, and then on programs, find Poser Executable file in the list, click on the question marks or X's and select allow.
See bagginsbill post a few slots up for the explanation.
Quote - IS there an entry in the Zone Alarm programs list for 127.0.0.1? That's part of Poser 8 as well.
127.0.0.1 might also be named localhost. I am on a mac for poser but do work on win machines at work form time to time. Don't use zone alarm here. But have had issues with firewalls and what win thinks is the "localhost" and a sql app several years ago. Meaning you might not see the ip addy of 127.0.0.1 in zone alarm, but you might see the name localhost instead.
Gary
Because localhost is always the address of the computer itself, so it can talk to itself without knowing an official IP adress (which it may have multiple or even none)... Having roughly 65000 ports for communication with the same IP address, where's your problem? Lots of other applications do communication via sockets (IP address+port), too.
Poser doesn't need an Internet connection. It does need a TCP connection, both client and server, to communicate with itself internally. The world has somehow come to the point that all TCP communication is deemed "Internet", even when it isn't.
Whatever Zone Alarm calls these things, Poser needs to accept connections, but only from your own computer, and it needs to make connections, but only to your own computer. This is over the local loopback address, 127.0.0.1. Nothing else has to be open.
Note that Poser will not accept a connection from outside your computer, even if you set up your firewall to allow it.
