Sun, Jan 5, 7:21 AM CST
Subject: Animating ecosystem materials
offrench ( ) posted Thu, 20 August 2009 at 11:49 AM ยท edited Sat, 04 January 2025 at 6:49 AM
I am trying to animate a terrain and its materials in Vue 7.4 (latest build).
I am using the exact sequence detailed in the manual to animate materials:
  • move the time slider to 3 seconds
  • open the material summary panel
  • double click my material to edit it
  • load a new material to replace the former one
    At that point, I am supposed to get the warning message "you are modifying a material at a non zero time, do you want to animate it", but I get nothing at all. No way to create a material keyframe. It just replaces the old material with a new one.
I am using materials that contain dynamic ecosystems and noticed it does work when using simple non ecosystem materials.
Is there a workaround to animate ecosystems?
Is it a bug or is it simply impossible to animate ecosystems?
Fantasy pictures, free 3d models, 3d tutorials and seamless textures on Virtual Lands.
Mazak ( ) posted Thu, 20 August 2009 at 12:24 PM
In your Options General Preferences tab click on Restore disabled messages. That should bring the dialog box back!
Mazak
Google+ Bodo Nittelย
Mazak ( ) posted Thu, 20 August 2009 at 12:31 PM ยท edited Thu, 20 August 2009 at 12:38 PM
I did a quick test; and **Yes** material animation in eco-systems is possible. ๐Ÿ˜„
Mazak
offrench ( ) posted Thu, 20 August 2009 at 3:57 PM
Sorry, I did not made myself clear in the last sentence of my message.
In fact what I want to animate is the terrain material itself, not the material used in the ecosystem objects.
I want to have a terrain change materials :
Jungle -> cut down trees -> eroded grassland
I made other tries with Infinite 7.4 and 7.5 PLE.
It is possible to have material animation, but not if the first two materials include ecosystems. .
What I could get is a transition of this type:
normal material -> normal material -> ecosystem material
With any other combination, there is no animation and no material keyframe created.
If I start with an ecosystem material, there is no material animation possible at all.
I tried to trick it by first creating an animation with standard materials and then replacing them with ecosystems. This destroys the existing keyframes.
Mazak ( ) posted Thu, 20 August 2009 at 4:25 PM
Have you seen the animation example tutorial "Animated Eco-Population"? If I load the scene I can edit the underlying material flat gray and animate it. At last frame I change color to red and Vue asked for animation material and it did the correct color change.
You say you load a new material in editor, maybe here is the error?!? Change the material setting in existing material do not load a new material! A new material load break the animation process.
Mazak
nruddock ( ) posted Thu, 20 August 2009 at 5:19 PM
It seems clear from what you've tried, that Vue won't let you change EcoSystems.
I suspect the only solution is to split the animation into two segments and use a seperate copy of the scene file for each segment so that you can apply the two different EcoSystems.
offrench ( ) posted Fri, 21 August 2009 at 12:58 AM
Quote - Have you seen the animation example tutorial "Animated Eco-Population"?
Where did you find it? I have looked in the animations tutorials files and it does not seem to be there.
I have tried to animate some of the ecosystem properties (density) but to no avail. If I start with an ecosystem material, it is impossible to create a material animation keyframe.
Mazak ( ) posted Fri, 21 August 2009 at 2:55 AM
Here have a look. It explain eco animation very well. Have you download the extras CD too?
Mazak
Mazak ( ) posted Fri, 21 August 2009 at 3:04 AM
I you want, you can PM me with your e-mail address. The file has only 3MB in size. ๐Ÿ˜‰
Mazak
offrench ( ) posted Sat, 22 August 2009 at 1:21 PM
Hi, Mazak. No need to send me the file.ย
I have understood why it did not work for me. It is a 7.5 functionality as indicated on the product page, and it was not included in the 7.4 update (which is the one I use).
I will upgrade to 7.5 if need arises.
Thanks for your help.
Mazak ( ) posted Sat, 22 August 2009 at 1:29 PM
OK, no problem ๐Ÿ˜„
Mazak
