Fri, Nov 22, 11:25 PM CST
Subject: Stitching together image sequence.bmp/tiff
santolina-sailor ( ) posted Tue, 25 August 2009 at 2:36 PM · edited Fri, 22 November 2024 at 10:43 PM
Hello,
Could some one recomend some software that will stitch together an image sequence from poser in bmp format into an AVI.
thanks
pete
TrekkieGrrrl ( ) posted Tue, 25 August 2009 at 5:41 PM
 Not sure if AnimationShop is available anymore. It used to come bundled with Paintshop Pro.
I believe that Photoshop can do it as well, but since I have Animation Shop from way back.. I've never tried .
Actually, Windows MovieMaker may be able to do it. It can import images into a movie. But it won't output .avi, only wmv
wyrwulf ( ) posted Tue, 25 August 2009 at 5:44 PM
Virtualdub. Works well, and free.
www.virtualdub.org/index
Tashar59 ( ) posted Tue, 25 August 2009 at 10:49 PM
Attached Link: wax
yep, Virtualdub. Another free one is WAX.
santolina-sailor ( ) posted Wed, 26 August 2009 at 12:28 AM
Hi,
I have a copy of virtual Dub but just cant find where to import the sequence of images .
pete???
Dale B ( ) posted Wed, 26 August 2009 at 6:06 AM
Select import, then select the first frame of the image sequence. Some apps have a 'numbered stills' checkbox that tells the app what the import is. Others simply look and see if there are other named images with sequencial numbers in the filename, and import the whole batch. Yet others require you to click on the list of file types, and you'll find the option buried amongst all the other options.
wyrwulf ( ) posted Thu, 27 August 2009 at 11:30 AM · edited Thu, 27 August 2009 at 11:31 AM
In Virtualdub, Menu'File'Open video file... or Ctrl+O. For an image or video sequence, check Automatically load linked segments. Click the attached image for full size.
santolina-sailor ( ) posted Thu, 27 August 2009 at 11:43 AM
Cheers thanks for that
pete
