Not sure if AnimationShop is available anymore. It used to come bundled with Paintshop Pro.
I believe that Photoshop can do it as well, but since I have Animation Shop from way back.. I've never tried .
Actually, Windows MovieMaker may be able to do it. It can import images into a movie. But it won't output .avi, only wmv
Select import, then select the first frame of the image sequence. Some apps have a 'numbered stills' checkbox that tells the app what the import is. Others simply look and see if there are other named images with sequencial numbers in the filename, and import the whole batch. Yet others require you to click on the list of file types, and you'll find the option buried amongst all the other options.
Hello,
Could some one recomend some software that will stitch together an image sequence from poser in bmp format into an AVI.
thanks
pete
