Tue, Feb 11, 1:50 AM CST
Subject: New Bug???
TygerCub ( ) posted Tue, 17 July 2001 at 5:21 PM ยท edited Fri, 02 August 2024 at 7:53 AM
I've run across the following message a couple of times when trying to load items from the 'free stuff' section: "The file has a newer version number than expected. Poser will attempt to read anyway." Has anyone else run into this? Should I reset something?
bloodsong ( ) posted Tue, 17 July 2001 at 5:33 PM
heyas; no, this is fine. it happens if you try to load a poser 4 figure into poser 3. or a poser 4.118 figure into poser 4. or a 4.03 into a 4.118. or a pro pack into anything. ;) if/when the figure loads, just re-save it to your library, and that will set the version number to your current version. (you can also change it in the cr2, if you like; it's right at the top. labelled 'version.' :) )
Moonbiter ( ) posted Tue, 17 July 2001 at 5:37 PM
I believe this occurs when you use an item that was made in the pro-pack and you only have 4.0.3. At least that is when I get it. I've not had a problem other than getting the message box, so I wouldn't worry about it.
atthisstage ( ) posted Tue, 17 July 2001 at 6:46 PM
I got it when I had vers 4 of Poser and before I got the CL upgrade to 4.03.
doozy ( ) posted Tue, 17 July 2001 at 8:13 PM
Pro Pack claims to be version 4.2, I believe, so it beats 4.03. But every time this has happened to me, it loaded OK anyway.
melanie ( ) posted Wed, 18 July 2001 at 8:02 AM
I've been getting that for as long as I've used Poser 4, even before Pro Pack came out, so that's not it. It usually happens when I use a pose or texture or something. Never figured out why. It's even happened on occasion on something I created on my own character, saved, and reused on the same figure. Go figure! Melanie
