Are you trying to change skin tone instantly or is this a gradual change that you are trying to do?
Frederick
Poser By Design
I've found that it's not possible to apply these nodes to all bodyparts and groups by simply using "select all" and "apply to all". If doing so you loose the animation of the texture (even if it seems to be "on" it doesn't work)
You have to select every single part of your character and apply the textures and toggle animation every time - one by one.
Maybe it's a bug in Poser 8. Or a feature. Don't know.
When using "Select All" and "Apply to All" be sure to have ALL nodes selected, not just the Poser Surface :) Otherwise the nodes won't copy.
Oh, I did that. I know how to copy the nodes and textures.
But (in Poser 8) the "animation on" wasn't applied to the other material zones - although I checked it... I did some test-renders of different frames and some of the material-zones hadn't changed so I had to check the little key-symbol in the blender node one by one.
Maybe someone can help me doing this..:
Is it possible to change a texture of a figure/character during an animation (Poser 7/8)?
E.g. - change the eyecolour from blue to green, the skin from pale to dark etc?
Its there a tutorial for this?
Thank you.
A.
