Mon, Feb 3, 11:07 AM CST
Subject: HELP! What do I do To.............Almost 20 questions for you!
TIRROCCIA ( ) posted Sat, 05 September 2009 at 2:41 PM · edited Mon, 03 February 2025 at 11:01 AM
What size should my preview window be?
What size should I render my image?
How do i get the building to scale,(really bad on the diles-is there a "set" size?)
I have poser 6
What is the best render settings?Not the size, but the how.
I have a large runtime, should i put it on a diffrent drive to speed up poser?
Can i save a meterial setting? and How?
is there a way to put all the clothing in a set together to  dress a "doll"?if so can i save it?
other then here and RDNA, is ther other "tut" sites i can check out?
Thank you all for any and all help
SeanMartin ( ) posted Sat, 05 September 2009 at 2:58 PM
Preview window: as large as possible for your monitor size. Not so big that you cant move it, but as big as you can get it.
Render size: depends on the image, but I always do mine at 2000 pixels on the shortest dimension.
Building to scale: start with a character so you have a measure. Load in the building, with the door near your character. Scale everything up and down so the door height is comfortable.
Best render settings: again, it depends on your image. I use the default Firefly with ambient occlusion for all lights, but that;'s just my preference.
Putting your large runtime on another drive wont solve the problem. Set up a second RT and put that on the external, but keep your main RT with the application and keep it lean. I set up an RT for every new series of images, so I can archive it with the finals and then take it out of commission so it doesnt slow down my Poser.
Dressing the doll and saving it: yes, you can do this. Build your character and all her stuff. Click on the body, then hit the + sign in the figure library. Poser will ask if you want to save just the figure or the entire group. Tell it the group.
TIRROCCIA ( ) posted Sat, 05 September 2009 at 3:52 PM
TYTYTYTYTYTYTYTY
geep ( ) posted Sat, 05 September 2009 at 4:13 PM · edited Sat, 05 September 2009 at 4:20 PM
Attached Link: Poser 6 Tutorials
*(click the image to view full size) (click the link above the image to view the index for the tuts)*
Did someone sat .......... "tuts?" :biggrin"
Got over 100 tuts at good ol' Poser U if you click the link below.  😄
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
FightingWolf ( ) posted Sat, 05 September 2009 at 7:02 PM
Wow geeps, I knew you had lots of tuts, but I didn't know it was that many. Maybe one day I'll be able to have that many ha ha ha.
Frederick
Poser By Design
TIRROCCIA ( ) posted Sat, 05 September 2009 at 7:29 PM
again I say LOUDLY: THANK YOU!
