Preview window: as large as possible for your monitor size. Not so big that you cant move it, but as big as you can get it.
Render size: depends on the image, but I always do mine at 2000 pixels on the shortest dimension.
Building to scale: start with a character so you have a measure. Load in the building, with the door near your character. Scale everything up and down so the door height is comfortable.
Best render settings: again, it depends on your image. I use the default Firefly with ambient occlusion for all lights, but that;'s just my preference.
Putting your large runtime on another drive wont solve the problem. Set up a second RT and put that on the external, but keep your main RT with the application and keep it lean. I set up an RT for every new series of images, so I can archive it with the finals and then take it out of commission so it doesnt slow down my Poser.
Dressing the doll and saving it: yes, you can do this. Build your character and all her stuff. Click on the body, then hit the + sign in the figure library. Poser will ask if you want to save just the figure or the entire group. Tell it the group.
Attached Link: Poser 6 Tutorials
*(click the image to view full size) (click the link above the image to view the index for the tuts)*Did someone sat .......... "tuts?" :biggrin"
Got over 100 tuts at good ol' Poser U if you click the link below.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Wow geeps, I knew you had lots of tuts, but I didn't know it was that many. Maybe one day I'll be able to have that many ha ha ha.
Frederick
Poser By Design
What size should my preview window be?
What size should I render my image?
How do i get the building to scale,(really bad on the diles-is there a "set" size?)
I have poser 6
What is the best render settings?Not the size, but the how.
I have a large runtime, should i put it on a diffrent drive to speed up poser?
Can i save a meterial setting? and How?
is there a way to put all the clothing in a set together to dress a "doll"?if so can i save it?
other then here and RDNA, is ther other "tut" sites i can check out?
Thank you all for any and all help
