Sun, Feb 9, 3:28 AM CST
Subject: External renderer not working
corysea ( ) posted Sat, 05 September 2009 at 3:56 AM · edited Sun, 02 February 2025 at 10:14 PM
Friends,
My external renderer has stopped working.  The black screen shows the usual progress however the timing steps are always the same and very slow, no matter whether an ordinarily fast or slow TGA is being processed. No actual render (in my case tga) is actually produced. This has happened before and was one of the reasons that I wiped my hard drive and reinstalled everything only about a month ago. I do not want to do this again and Vue 7.5 is basically useless to me if the external renderer does not work. I am using a Vista 64 bit 4 core computer.
Many thanks,
Cory Sea
Crowning ( ) posted Mon, 07 September 2009 at 3:57 PM
Quote - Friends,
Many thanks,
Cory Sea
Did you try a Rendercow on your local PC only? If this instance would work it'd be a network problem.
Next step would be to look for the firewall settings on all of your PCs.
Tom
corysea ( ) posted Mon, 07 September 2009 at 5:56 PM
Thank you. I'm not doing any network rendering or using the render cow. I'm only trying to render an animation using the external renderer on the one computer.
Cory
Eagle66 ( ) posted Thu, 10 September 2009 at 2:26 PM
The latest 7.5 release of Rendercow (HyperVue) is broken and all of us are waiting on a fix.
http://www.cornucopia3d.com/forum/viewtopic.php?t=9400&highlight=network
