Mon, Feb 10, 3:33 PM CST
Subject: displacing eyebrows
Believable3D ( ) posted Mon, 07 September 2009 at 11:12 PM · edited Mon, 10 February 2025 at 3:28 PM
All, I'm trying to displace V4's eyebrows, but no matter how high I go with the displacement settings, they just don't seem to want to displace. I'm just using the head map for the brows. Am I missing something with the mapping? I was going to try to compare it to how others have done it, but I'm not seeing any maps specifically for the eyebrows in other sets.
Any secrets?
______________
rsg ( ) posted Mon, 07 September 2009 at 11:56 PM · edited Tue, 08 September 2009 at 12:10 AM
Two words: Trans-mapped brows.
They use the eyebrow material zone on V4(which is normally unused), most sets don't seem to come with them but some do. They usually mention that as an option. Check out this promo for "Little Miss Lotta" by SaintFox to see what they look like.
http://market.renderosity.com/mod/bcs/index.php?ViewImage=103583
Edited to add:
 You could also use the head texture in the eyebrow zone and probably create displacement that way. I'm pretty sure it has the exact same mapping as the head. Just make sure to make the zone visible(you need to select eyebrow from the body part menu and go to parameters and check visible). It's off by default, it's not really needed with painted on brows - but some merchants use this even with painted brows as a way to give you a wide range of options for the eyebrows.
Believable3D ( ) posted Tue, 08 September 2009 at 12:22 AM
Oh, bingo!
Thanks!
______________
rsg ( ) posted Tue, 08 September 2009 at 12:29 AM
You're welcome.
I haven't tried it that way with VSS but, by default VSS does some weird things with trans-mapped eyebrows(it could just be the eyebrow zone, I only tried it once and haven't gotten back to it yet or I could have messed up someplace but I don't think so.) . Just something to keep an eye on anyways. Best of luck to you.
Believable3D ( ) posted Tue, 08 September 2009 at 1:09 AM
Meh. It's pretty tricky. It's way bigger than the brow per se... Trying to control it via transmap, but that doesn't seem to be working; it's not lining up, and even the brows themselves don't look right. I may have to make this a long term learning process and skip it for this particular character.
______________
Believable3D ( ) posted Tue, 08 September 2009 at 1:15 AM
Hm, there's definitely some extreme weirdness here. Now that I look at the face headon, it looks like the brow texture is upside down in preview (??)....
______________
nabob21 ( ) posted Tue, 08 September 2009 at 1:18 AM · edited Tue, 08 September 2009 at 1:19 AM
Online Now!
There are a couple of tutorials about making an eyebrow mask that may help you. They were originally made to change the colour of V4's eyebrows but they also work to mask the displacement of the brows. The process is also fairly easy and only takes a few minutes. I believe that one of the tutorials is on the Daz3d site in the tutorials section. It is called easy colour changeable eyebrows. Here is a link:
http://www.daz3d.com/i.x/tutorial/0/
edit: The link doesn't work perfectly. At the top of the page change the view to textures and maps.
Believable3D ( ) posted Tue, 08 September 2009 at 1:20 AM
Yikes, I've got some serious issues going on. The above image was from Poser Pro. Opened up the file in P8, and the eyebrows are in the right spot, but notice that my face morph has disappeared visually (even though it's showing as set at 1 in the palette).
______________
Believable3D ( ) posted Tue, 08 September 2009 at 1:26 AM
Thanks, nabob, I'll take a look. I think part of my present problems aren't simply workflow, but software issues.
______________
