I have had this error happen when Bryce can't find an .mtl file to go with the .obj (not always). If you get the UVMapper program (from uvmapper.com) & run the .obj thru that so that it has texture coordinates written into the .obj file, it usually won't happen. There may be other situations in which this happens, but I haven't run into them (yet).
I get the exact same error in bryce 4 when I tried to import my Poser model, but I used VueMaster then, but stopped since it doesn't do what I need it to do. So.. I was kind of thinking that you may need more memory? I only have 128MB atm, and my Angel is 16MB, which shouldn't be a problem, but then again ~shrugs~
It could be the size of the file. The largest I've ever loaded into Bryce using Windows 98 or ME is 12.5 Meg (larger files failed...). I have better luck loading under NT (I have a dual-boot system on the Win98 machine). Under NT, I've successfully loaded 117 Meg. Usually I get an error message that sez "Unknown error, out of memory", but I've seen the one you've posted too.
