Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 09 11:05 am)
Go to 63.
On the main menu hit Edit: Memorize All.
Go back to frame 1.
Hit Edit: Restore All.
Cut the timeline down to 1 frame.
Save the result.
My python page
My ShareCG freebies
(Just for completeness, I should add: If you still want the original file as well,
be sure to save it under a different name!)
My python page
My ShareCG freebies
The simplest is to create a keyframe at the desired frame, delete all other keyframes, then drag the single remaining keyframe to frame 1 and finally trim the animation length before saving.
The above assumes you're not using dynamic cloth (requires exporting cloth objects or morph targets for them at the desired frame) or hair (no way to isolate a single frame).
Time sensitive materials (e.g. movie textures) will also require special treatment
I have 280 frames and one has perfect everything. The rest not so much. i would like a new sceene with only frame 63. it's not under export or save as, any ideas?
