Fri, Jan 3, 8:40 PM CST
Subject: Actuall character height ?
Max_Raptor ( ) posted Fri, 18 September 2009 at 3:11 AM · edited Wed, 01 January 2025 at 2:44 AM
Sorry if this is a silly question or if I did not do my searches ok here
but I am trying to find out if there is a tool to get the actual hight of a character
for example V4 ?
I need to scale them more or less exact and I feel the general scale option for a body
is not giving me what I need.
a Python script maybe ?
lesbentley ( ) posted Fri, 18 September 2009 at 5:26 AM
Place your character with its feet on the GROUND plain. Load a Poser box primitive. yTran the box until its bottom edge is level with the top of the characters head. The value on the yTran dial will be the hight of your character in whatever units you have set Poser to use.
It's easier to align the box with the top of the head if you use an orthogonal camera, such as the Front of Left Camera.
Max_Raptor ( ) posted Fri, 18 September 2009 at 5:46 AM
Ahhhh see how simple it can be !! thanks alot for that tip :)
geep ( ) posted Fri, 18 September 2009 at 7:24 AM
Attached Link: "How Tall Is S/He?" tutorial
*(click image to view full size) (click link above image for the tutorial)*
Did someone say "height?" ... 😄
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Max_Raptor ( ) posted Fri, 18 September 2009 at 7:27 AM
Does it work ok in Poser Pro ?
hborre ( ) posted Fri, 18 September 2009 at 7:36 AM
It will work perfectly fine in all Poser versions.
TrekkieGrrrl ( ) posted Fri, 18 September 2009 at 8:25 AM
Could you set the scales in the early versions? Poser 4.. didn't that ONLY use PNU?
lesbentley ( ) posted Fri, 18 September 2009 at 9:26 AM
Yes, P4 only used PNU.
geep ( ) posted Fri, 18 September 2009 at 9:29 AM · edited Fri, 18 September 2009 at 9:31 AM
Pnu's in P4? ... Yup ... But ...
You can just use Dr Geep's Scale (DGS). ... 😄 ...
DGS works in ALL versions of Poser from P1 through P8 and beyond.
(because the Pnu uses exactly the same scale as the Wavefront OBJect unit scale)
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
