Thu, Jan 9, 7:28 AM CST
Subject: Render Cache and Macs issue if you run two different versions at once.
grichter ( ) posted Wed, 23 September 2009 at 1:19 PM · edited Thu, 09 January 2025 at 7:22 AM
 I have no idea if this applies to the windows versions of Poser.
On a mac, your render cache for both PoserPro and P8 are stored in the same place. If you bounce back and forth between apps to use the render in background feature of pro, and or you have different settings of how many renders to save in cache between P8 and PoserPro....
Couldn't under stand why when I tried to compare two P8 renders I got  a test render I had run on PoserPro instead of the two P8 renders...and the fact that my P8 render cache had been erased because I have the render cache in PoserPro set extremely low at 2 and in P8 I have it set at 4.
Filed a bug report and hopefully they will change the path of the cache to align with the version number like they do with the settings in SR2.
Gary
Little_Dragon ( ) posted Wed, 23 September 2009 at 1:53 PM
Quote -  I have no idea if this applies to the windows versions of Poser.
It does.
bagginsbill ( ) posted Wed, 23 September 2009 at 2:24 PM
Really they are in the same place? That is very new, as in previous updates to SR1 for beta testing did not mix the two. They must have had a request from somebody to make them the same.
I had issues with this myself because I was doing a test render of the same scene in PPro and P8 and I couldn't do the swipe/compare thing from render cache. The Pro render was not in the P8 render cache. I had to save the two images and do a flip test comparison with another tool.
LOL
Every decision has pros and cons. Seems like the only solution is to have a preference parameter that lets you decide whether you want render caches separated or combined.
aeilkema ( ) posted Wed, 23 September 2009 at 3:50 PM · edited Wed, 23 September 2009 at 3:55 PM
It was an issue before SR1 as well. Whenever I've got Poser Pro and P8 open (with or without SR1) it does this render cache distortion. I'm using WindowsXP.
I must admit that I didn't report it though, since I haven't used Poser Pro that much, only for some testing lately.
Food for thought.....
Little_Dragon ( ) posted Wed, 23 September 2009 at 3:55 PM
P7 and P8, under WinXP, here.
grichter ( ) posted Wed, 23 September 2009 at 8:58 PM
John in support says it has been reported to the development team
Gary
