Tue, Nov 12, 8:53 PM CST
Subject: Has Anyone Every Had This Problem..Poser6
yakchat ( ) posted Wed, 23 September 2009 at 6:28 PM · edited Sun, 10 November 2024 at 3:08 AM
Regarding when I render manually(very basic settings)....in Poser 6....on occasion I get pixelated places all over my character, clothes, etc....
Has anyone had this happen and know what causes it?
Thank you for your input,
Carol/yakchat
BeyondVR ( ) posted Wed, 23 September 2009 at 7:23 PM
A couple of things come to mind.  First bump up the ray samples a bit, though this usually shows as bad antialiasing (jagged edges).  The other thing is that the map size is set at 1024 as the default.  Characters, and some other objects, have much larger texture maps.  Set for the size of the largest map used, for optimal results.
John
yakchat ( ) posted Wed, 23 September 2009 at 11:41 PM
I tried it and the same thing happened...and then I bumped it up more and it happened again....but thank you for trying to help me :-)
yakchat ( ) posted Wed, 23 September 2009 at 11:42 PM
ps..do you have any other ideas as to what it could be?
nruddock ( ) posted Thu, 24 September 2009 at 3:05 AM
Quote - ps..do you have any other ideas as to what it could be?
It could be one of several things, so a screenshot would be useful for diagnosing the cause.
yakchat ( ) posted Thu, 24 September 2009 at 4:43 AM · edited Thu, 24 September 2009 at 4:45 AM
Here is the screenshot...notice on his arm, hand, elbow, jeans.....and on her shoulder, back, and near the hair...thank you...ps..you will have to click on the image and enlarge it to the 100% that the screenshot was taken...
Lzy724 ( ) posted Thu, 24 September 2009 at 9:49 AM
I have had this happen also..... I have no idea what causes it, its a strange strange thing.  I typically just try to render it again, after closing poser and reopening, its almost like the mesh is coming through the skin.  I've never found an answer, and when it wont work, I just end up postworking it out. :(
yakchat ( ) posted Thu, 24 September 2009 at 4:59 PM
Oh my goodness...I was almost through with the postwork....pixel by pixel and also using the clone tool.....and screwed up on selecting all and merging as one..at some point and I have to start all over....I have found also that sometimes opening and closing Poser and re-rendering will fix the problem...but not this time...ughhhhh....very very frustrating...
thank you for your input hon....anybody else???
huggers, Carol
drewradley ( ) posted Thu, 24 September 2009 at 5:49 PM
I've had it happen in Poser 7 usually when I am using props such as Jepes animated "billboards" and others with a transmap. When that  happens I end up rendering in Poser 4 rather than firefly and that usually fixes it.  But that clearly isn't what is causing it on yours (at least I assume you don't have any trans maps on those textures) so...
I've also had it happen when I mess around with the "Post Filter Size". Put back to "1" and "Box" if it is not currently. Then if that doesn't fix it, change it to gausian and/or sinc. But I usually find that anything other than the default of "1" and "Box" leaves those marks you are seeing.
Just in case you don't know, that setting is on the right hand side, near the bottom, of the render settings menu (under options) in Firefly.
Now Playing
My Insomnia Presents
Blue Defender
