Tue, Jan 28, 5:52 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 6:42 am)
Subject: Loading content into Poser
Pandorian ( ) posted Sat, 03 October 2009 at 2:22 PM · edited Tue, 28 January 2025 at 5:46 PM
Okay, I've created and marketed a figure here on Rosity which is currently in the Marketplace and is compatible with Poser 5, 6 and 7.  I've just installed Poser 8 on my computer and loaded this figure into Poser 8.  Now, I've skimmed through the Poser 8 path in my computer (Program files/Smith Micro/Poser 8/Runtime/ etc....) and I see the folders for my product, however, when I open up Poser 8 and attempt to load that figure in, I cannot find it anywhere.
Any suggestions would be greatly appreciated.
-J.
Pandorian's Website.... aka......
BAR-CODE ( ) posted Sat, 03 October 2009 at 2:31 PM
Mmmm did you not have to make the ZIP for your product Poser ready  ..
And now its in the store .. so how did you do that if you cant find your OWN product ?
You are not making sence....
And did you set the p8 reading of runtimes the right way in P8 or the new way .?
Chris
Quote - Okay, I've created and marketed a figure here on Rosity which is currently in the Marketplace and is compatible with Poser 5, 6 and 7.  I've just installed Poser 8 on my computer and loaded this figure into Poser 8.  Now, I've skimmed through the Poser 8 path in my computer (Program files/Smith Micro/Poser 8/Runtime/ etc....) and I see the folders for my product, however, when I open up Poser 8 and attempt to load that figure in, I cannot find it anywhere.
-J.
IF YOU WANT TO CONTACT BAR-CODE SENT A  PM to 26FAHRENHEIT  "same person"
Chris
My Free Stuff
PhilC ( ) posted Sat, 03 October 2009 at 2:42 PM
The default Poser 8 installation will place library content in a shared directory named "Poser 8 Content". You'll see this listed in the Poser library along with another section named "Downloads"
If you have installed your zip to the root Poser 8 folder you will need to add that as a new library using the "Add Library" icon.
Pandorian ( ) posted Sat, 03 October 2009 at 2:48 PM
Excuse me if I "lost" you Chris.  But this product has been and still is in the marketplace for a few years.  Since it's creation, it's been made compatible with Poser 5 and 6 and then later when Poser 7 came out, it was tested to be compatible with Poser 7.  I have just now today, received and installed Poser 8 on my computer and wanted to see if that same creation is compatible with Poser 8.  I loaded it into the Poser 8 Runtime (as I've done many times before on Poser 5,6 and 7).  This is where the problem begins, I navigated through path destination on my computer (Program Files/Smith Micro/Poser 8/Runtime/ etc.... and I can visually see the folders I created for my product there, however, when I open the Poser 8 program and try to load the figure I just installed into Poser 8, I don't see any of the folders for it anywhere.
What exactly do you mean by setting the reading of Runtimes in P8 the right way or new way?
PhilC ( ) posted Sat, 03 October 2009 at 2:55 PM
Depending on what options you choose when installing Poser 8 the Program Files/Smith Micro/Poser 8/Runtime may not have been included in the default library. You'll need to add it manually by clicking on the add library icon.
Once added you'll be able to see your content.
bagginsbill ( ) posted Sat, 03 October 2009 at 2:59 PM · edited Sat, 03 October 2009 at 3:00 PM
This cannot be figured out if you never say what the path is. You keep saying Poser 8/Runtime/ ... and never finish.
There have been bugs regarding paths. Perhaps you found one. But if you don't tell us any details, we cannot guess. Most have been fixed in SR1.
Also, you did not which version of Poser 8 you have - there are 3.
Pandorian ( ) posted Sat, 03 October 2009 at 3:24 PM
Bagginsbill:
The Poser 8 version is 8.0.0.10157 (just installed it about an hour ago)
Here are the file paths to the pertinant files:
RuntimelibrariesCharacterPandorian
   4S Wring Gen 2.cr2
RuntimelibrariesPosePandorian4S Wring UD MAT POSE
   All Tex Removed.pz2
   All-PBL Black Theme.pz2
   All-PBL Red Theme.pz2
   All-Plain Black Theme.pz2
   All-Plain Red Theme.pz2
RuntimeGeometriesPandorianLebron 4 Sided Ring
4S Wring Gen 2.obj
RuntimelibrariesPosePandorian4S Wring Poses
   Mortal Sin Aggressor.pz2
   Mortal Sin Victim.pz2
   Trapped In Ropes.pz2
RuntimetexturesPandorian4S Wring UD
RuntimeReadMe'sPandorian Chronicles
   4S Wring Gen 2 ReadMe.txt
   License.txt
RuntimetexturesPandorian Templates4S Wring UD
PHILC: Thank you for explaining that to me.  I did as you suggested and everything appeared as it should.  Now is this a one-time creation or do I have to do this whenever I install content to Poser 8, (if I install it the same I did to Poser 6 and 7 via their Poser root folder)?
Also, for the sake of Poser version uniformity for the marketplace when creating content, would it be prudent to keep the ROOT POSER FOLDER as the final destination when creating new content for the Marketplace?
Thanks
-J
PhilC ( ) posted Sat, 03 October 2009 at 3:30 PM
Unless you opt to remove them, the Poser 8 library panel will continue to show all your loaded runtime libraries.
I suggest creating zips just as before but include a note in the readme explaining that the default Poser 8 library may be in a remote folder not in the local runtime. The user may install to either, just be sure that all required libraries have been added to the library panel.
Pandorian ( ) posted Sat, 03 October 2009 at 3:46 PM
Thanks so much PhilC, you have been extemely helpful in explaining this to me and I really appreciate it.  :)
bagginsbill ( ) posted Sat, 03 October 2009 at 4:45 PM
buidl 10157?!? The first one?
There was an immediate (day of release) hot fix that had to be run. 10157 is not going to work.
Since then there is SR1. Get that. Then we debug. Not before.
Pandorian ( ) posted Sat, 03 October 2009 at 6:26 PM
Bagginsbill,  no need to debug as PhilC immediately identified and helped resolve the problem.
Thanks however for taking the time to state the obvious.
TrekkieGrrrl ( ) posted Sat, 03 October 2009 at 6:31 PM
 It's a daft idea to alienate yourself by snapping at people who are trying to help.
No matter if your immediate problem was solved, you should - in fact I URGE you to - install both the hotfix and SR1. Without those two, Poser 8 will not be a fun experience. And how can you create new Poser content in a version that doesn't really work?
It's up to you of course.. but then don't come whining whenever something ELSE won't work for you.
Pandorian ( ) posted Sat, 03 October 2009 at 7:36 PM
First off TrekkieGrrrl, I wasn't snapping at anyone.  IMO the response was laced with a bit of sarcasm and I responded accordingly.  Whether or not it was only he truly knows, if I misinterpreted his response, then he has my sincerest apologies.  My intention IS and ALWAYS was to install the SR1 and hotfix, PhilC just happened to address my issue before I got around to it.
As for your provocative and unnecessarily inane "whining" comment, it's not even worth the effort of a response.  Regardless, you have yourself a nice day.
Dead_Reckoning ( ) posted Sat, 03 October 2009 at 8:08 PM
Quote - Bagginsbill,  no need to debug as PhilC immediately identified and helped resolve the problem.
No idea if you have windows or mac
Here is the link to get the Service Release 1
Poser 8 Service Release 1 (SR1) 8.0.1 Windows
http://my.smithmicro.com/win/poser/updates.htmlPoser 8 Service Release 1 (SR1) 8.0.1 Mac
http://my.smithmicro.com/mac/poser/updates.html
version 8.0.1.10434
As BB mnetioned, there is and update mith many fixes, P8 SR-1.
One never knows when they may encounter a glitch, especially when using the original P8 version with no updates. applied.
Just a my $0.02 worth.
"That government is best which governs the least, because its people discipline themselves."
Thomas Jefferson
Pandorian ( ) posted Sat, 03 October 2009 at 8:26 PM
Thanks for the help and links Mariner, it's greatly appreciated.  :)
