Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 9:02 am)
In using your magnets, did you inadvertently just slightly manipulate an adjacent zone? If so, you need to spawn morph targets and/or export object morphs for those zones as well or you'll have a rather odd looking transition between those zones (for example, the transition between the neck and the head). If perhaps you didn't have the magnet effect an adjacent zone, maybe you should - it makes a much smoother transition.
I'm sure the 2 had a good bit of intersecting with each other. I've saved the Mags as props grouped together. Perhaps I should load 1 at a time and spawn from there. It'll be a bit before I can try it but thank you very much for giving me a direction to try. (Other than forward movement of my PC thru the nearest window) Thanx again, good idea, perhaps before I never had more than 1 magnet at a time...........HD
Well I got 90% of what I aimed for, finally just settled on saving the 3 mags as 1 prop. Yes JB, "kielomorph" was at 1 and I tried to match the V3 head with mags and spawn morph target. Clicking on the mags as a prop gets me there so the end result is what I was shooting for. Will have to remember to apply them each time to each like character but worse things have happened. Thanx again everyone.....HD
I have loaded the Kielo 2 morph on V3. Set the head back to V3 which leaves an the neck looking a bit "funny". (I'm not laughing now, I was 2 days ago but not now) I use 2 magnets to get it where I want it and I may use 1 more later under the chin. I have spawned a morph target and also saved the neck as an obj to load as morph target, both of which give results that are worse than the start. (still not laughing). I'm pretty sure I've done this before but darn if I can figure it out this. I feel like I'm missing something simple even in the manuals or forum searches that I've done. Its all been saved as I keep hoping poser elves will correct something each time I turn off the computer and walk away from it. So far no sign of any magical poser elves helping yet. I haven't used magnets in a while (maybe since P6) so thought I'd get an opinion or suggestion if possible. Pretty proud I got it to this point with the help of some mag tutes like Phil C's and others, now if I could just save it. Worse things have happened tho......hi ho and thanx.........
