I thought Bryce supported multi threading which would allow it to use multi processors?? He says "The premium render options require a lot of render time. Unfortunately, there is no multiple processor support. But not to worry. Many Bryce users have access to another computer or two, older ones, perhaps, or computers belonging to another member of the family." If someone knows please clarify this for me...thanks
They seem to be still operating under the assumption that Bryce is automatically the final destination where you will do all rendering and that everything will be Imported rather than Exported. For some (like me) that's actually true, as I will never be able to afford the higher priced programs, but for a lot of others it just 'ain't so. Even for me, though I expect Bryce will probably always be my final destination where I compose the scene and render, it would be nice to be able to export something that needs changing so I could make structural adjustments to it in say, Amapi & then re-import into Bryce. Oh well, maybe one of these centuries they'll get it all right.
There may be one convoluted way to do this (that is, export Bryce derived objects)--mind you I haven't tried it, but it should work. There are several programs, such as PhotoModeler (Lite version is free demo) that will allow one to make 3D meshes out of a series of photographs of an object taken from several different angles. Suppose you used such a program, but instead of photos, you use several different renderings of your object in Bryce--each rendering from a different angle. I don't know why this wouldn't work. Sorry no link for PhotoModeler. Somewhere in the Renderosity forums there are several threads discussing these sorts of programs (most are quite expensive; some are easier to use than PhotoModeler). If my explanation isn't clear, let me know and I'll try to be more precise.
Attached Link: http://bryce-alive.net/bryce5review/
I'm sure a lot of you have seen this, but for those who havn't, here is a good review of Bryce 5 I found at Brycetech. It's worth the read. kaom
