Wed, Nov 20, 2:39 AM CST
Subject: Can V4 have an overbite?
jeffg3 ( ) posted Mon, 12 October 2009 at 8:49 PM · edited Wed, 20 November 2024 at 12:19 AM
Can V4 have an overbite? I'm looking for morphs that will push the lower jaw back and give the familiar overbite/weak chin appearance.
So far I've found zilch.
LukeA ( ) posted Mon, 12 October 2009 at 8:56 PM
I think I can make one pretty easy. Post a pic of it.
LukeA
My latest novel
Propschick ( ) posted Mon, 12 October 2009 at 9:07 PM
Zbrush will let ya make a custom morph for that
Ever stop to think, and forget to start again?
pakled ( ) posted Mon, 12 October 2009 at 9:08 PM
isn't there a dial for jaw size? I know I've seen one on her...I think...
LukeA ( ) posted Mon, 12 October 2009 at 9:10 PM
I have been playing with it and we need to make a morph for it. I can do that now if I had a good pic.
LukeA
My latest novel
LukeA ( ) posted Mon, 12 October 2009 at 9:24 PM
This is a quick on I did - has a morph for the chin and lower jaw. I based it on a pic from Google so it looks like an older lady's chin
LukeA
My latest novel
jeffg3 ( ) posted Mon, 12 October 2009 at 11:04 PM · edited Mon, 12 October 2009 at 11:05 PM
Sorry - I've been out. That look really cool.
I'm looking for something along these lines:
Even the lower lip sort of retreats.
jeffg3 ( ) posted Mon, 12 October 2009 at 11:06 PM
Also:
Keith ( ) posted Mon, 12 October 2009 at 11:50 PM
The tooth overbite is easy: upper and lower jaws can be moved independently, so just move the upper jaw out a bit (or lower in).
jeffg3 ( ) posted Tue, 13 October 2009 at 1:13 AM
How?
None of the Jaw morphs seem to hit it correctly.
I must be missing something.
LukeA ( ) posted Tue, 13 October 2009 at 1:18 AM
Select the lower jaw and use the translate parameter dials to move it around
LukeA
My latest novel
raven ( ) posted Tue, 13 October 2009 at 11:46 AM
Attached Link: http://www.youtube.com/watch?v=Nri1WC1uVX4
How about if you just select the head and then use the JawInOut morph to give an overbite, then there's no need to mess about with the upper and lower jaw's dials at all. Does that give the effect you are after? Here's a quick anim showing the JawInOut morph being used (from value 0 to 1.5) then opening the lips and mouth better to show before finally closing the mouth to show the teeth overbite at the end if that helps any.
raven ( ) posted Tue, 13 October 2009 at 11:52 AM · edited Tue, 13 October 2009 at 11:53 AM
file_441194.txt
If you can't see the effect properly on the YouTube vid, here's the anim in a zip file for you to look at at your leisure if it helps. It's about 85kb. Save it without the .txt extension to get the zip.
jeffg3 ( ) posted Tue, 13 October 2009 at 5:58 PM
That's exactly what I'm looking for.
Where is the JawInOut morph?
I must be blind.
dadt ( ) posted Tue, 13 October 2009 at 6:43 PM
Online Now!
The one you need is "chin depth" in the "Lower Face"  morphs
jeffg3 ( ) posted Tue, 13 October 2009 at 7:09 PM · edited Tue, 13 October 2009 at 7:12 PM
Actually I found it - JawIn-Out under Morphs|Expressions > Base
