Thu, Nov 28, 7:58 PM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: erc , valueOpKey in Poser 7
markschum ( ) posted Wed, 14 October 2009 at 10:42 PM · edited Thu, 28 November 2024 at 5:45 PM
I have got a freebie item that was made in Poser 8 . The erc dial that controls two opening parts uses a ValueOpkey statement with some valuekey statements rather than the valueOpDelta stuff that I am used to.
In Poser 7   (7.02.132) it seems to work, but as though the values are much larger than they should be.
Does anyone know whats happening. Its possible my Poser install is damaged , but everything else seems to work OK.
regards
msg24_7 ( ) posted Thu, 15 October 2009 at 1:49 AM
Sounds like dependent parameters to me...
Haven't created anything with them yet, but had a look at them, when they were introduced in Poser 7.
Yesterday's the past, tomorrow's the future, but today is a gift. That's why it's called the present.
ockham ( ) posted Sun, 18 October 2009 at 8:23 PM
I used DP a lot in 7, and found that the items I made in 7 work exactly the same in 8.
I don't think there's a difference at the CR2 level, though the interface in 8 makes it
very easy to use and create DP setups.
Do you know if this item actually worked right in 8?   Or could it have been just plain wrong?
My python page
My ShareCG freebies
