Tue, Nov 19, 6:34 AM CST
Subject: OT DVD help please
RedPhantom ( ) posted Fri, 16 October 2009 at 11:04 AM · edited Tue, 19 November 2024 at 6:17 AM
Site Admin Online Now!
I have a DVD+RW that I'm trying to erase (actually a few of them) but my computer won't let me. I've tried in the drive it was burned on and a newer one but no luck. Does anyone have any suggestions?
LaurieA ( ) posted Fri, 16 October 2009 at 11:15 AM
What OS are you using?
RedPhantom ( ) posted Fri, 16 October 2009 at 11:40 AM
WIndows XP
Anthanasius ( ) posted Fri, 16 October 2009 at 11:42 AM
What software do you use for deleting your medium ?
Génération mobiles Le Forum / Le Site
RedPhantom ( ) posted Fri, 16 October 2009 at 12:04 PM
windows explorer
thefixer ( ) posted Fri, 16 October 2009 at 12:37 PM
Don't you use Nero or something similar for doing this, should be able to erase it with that!
Injustice will be avenged.
Cofiwch Dryweryn.
LaurieA ( ) posted Fri, 16 October 2009 at 12:49 PM
If you use XP, seems to me you should be able to right-click on the dvd in question and choose "Format" from the flyout menu. It's not letting you do that?
RedPhantom ( ) posted Fri, 16 October 2009 at 3:05 PM
I have Nero but can't find an erase disk function.
 Right clicking doesn't give me a format option.
thefixer ( ) posted Fri, 16 October 2009 at 3:12 PM
What version of Nero are you using?
depending on which version, you may have 2 different exe files, you need the one called "startsmart" or something like that, the erase function is on that.
It would help to know which one you have though, because they are different.
The Nero on my Wife's computer is a different one to mine and works slightly differently.
Cofiwch Dryweryn.
markschum ( ) posted Fri, 16 October 2009 at 3:21 PM
I use Nero Express. At the bottom theres a MORE button that gives you Erase Disc and Disk Info options.  If your nero has those try that.
Stupid question bur are you certain that it is actually a RW disk ?
LaurieA ( ) posted Fri, 16 October 2009 at 3:57 PM
I get the "Format" option, but I'm using Vista. XP, if I remember correctly had the same function, so I'll echo markschum's question and ask if you're sure it's an -RW disk?...lol.
Khai-J-Bach ( ) posted Fri, 16 October 2009 at 4:04 PM
Attached Link: http://www.nero.com/eng/downloads-nero9-free.php
if it's older Nero, there's a free cutdown version 9 at the link
markschum ( ) posted Fri, 16 October 2009 at 4:07 PM
Adter the system has recognised the disc, I get a right-click menu option but ONLY when the disc is a RW type.  Thats why I asked  :)
I have had a lot of problems wirh disks burned by a friend. My drive does not allow me to erase them for some reason, I get an error. I have to assume that there is some alignment issue messing things up.
RedPhantom ( ) posted Fri, 16 October 2009 at 6:48 PM
Yes they are rw. I triple checked. And I was able to find the erase disk on Nero and it worked. Now I'll have to see if i can burn to it again. Thank you all for your help.
pakled ( ) posted Fri, 16 October 2009 at 7:44 PM
not to be silly, but why are you trying to erase a DVD? They're cheap enough that even I can afford them.
BTW - RW's don't work well for long-term storage. Ask Doc Geep about that, he has a tutorial...
But you never know, there could be a perfectly good reason.
RedPhantom ( ) posted Fri, 16 October 2009 at 9:13 PM
I want it for recording tv. I copied the stuff to a single write dvd and figured i'd use the rw for tv. my dvd recorder is fairly new and i don't have many dvd rws. I just went back to work so money is still tight and i'm saving it for p8.
Adom ( ) posted Fri, 16 October 2009 at 9:59 PM
**pakled
**I agree with you 100% - and I avoid cd/dvd/bd as much as possible - that is the worst data storage - always wait sooooo long to see anything - and handle it so carefully - it makes me sick - when I had my first laptop long time ago (HP) there was a removable cd drive so I immediatelly removed it and put another hard drive inside the same cover - didn't work by the way - but who cares:) - it was looooong time ago.
markschum ( ) posted Fri, 16 October 2009 at 11:06 PM
I use cd -rw for music and video. Its not long term storage and there is no downside except inconveniance to having an unreadable disc.
hborre ( ) posted Fri, 16 October 2009 at 11:47 PM
The basic problem with RW's is file corruption over time and usage.  Data storage is imbedded into a fluid matrix rather than a hard burn.  With time the molecular cohesiveness begins to breakdown and the data becomes unusable.
RedPhantom ( ) posted Sat, 17 October 2009 at 7:25 AM
Well I'm not saving the tv shows long. It's just so my hubby can keep up with stuff during harvet.
