WIndows XP
windows explorer
I have Nero but can't find an erase disk function.
Right clicking doesn't give me a format option.
What version of Nero are you using?
depending on which version, you may have 2 different exe files, you need the one called "startsmart" or something like that, the erase function is on that.
It would help to know which one you have though, because they are different.
The Nero on my Wife's computer is a different one to mine and works slightly differently.
Injustice will be avenged.
Cofiwch Dryweryn.
Attached Link: http://www.nero.com/eng/downloads-nero9-free.php
if it's older Nero, there's a free cutdown version 9 at the linkAdter the system has recognised the disc, I get a right-click menu option but ONLY when the disc is a RW type. Thats why I asked :)
I have had a lot of problems wirh disks burned by a friend. My drive does not allow me to erase them for some reason, I get an error. I have to assume that there is some alignment issue messing things up.
Yes they are rw. I triple checked. And I was able to find the erase disk on Nero and it worked. Now I'll have to see if i can burn to it again. Thank you all for your help.
not to be silly, but why are you trying to erase a DVD? They're cheap enough that even I can afford them.
BTW - RW's don't work well for long-term storage. Ask Doc Geep about that, he has a tutorial...
But you never know, there could be a perfectly good reason.
I want it for recording tv. I copied the stuff to a single write dvd and figured i'd use the rw for tv. my dvd recorder is fairly new and i don't have many dvd rws. I just went back to work so money is still tight and i'm saving it for p8.
**pakled
**I agree with you 100% - and I avoid cd/dvd/bd as much as possible - that is the worst data storage - always wait sooooo long to see anything - and handle it so carefully - it makes me sick - when I had my first laptop long time ago (HP) there was a removable cd drive so I immediatelly removed it and put another hard drive inside the same cover - didn't work by the way - but who cares:) - it was looooong time ago.
Well I'm not saving the tv shows long. It's just so my hubby can keep up with stuff during harvet.
I have a DVD+RW that I'm trying to erase (actually a few of them) but my computer won't let me. I've tried in the drive it was burned on and a newer one but no luck. Does anyone have any suggestions?
