Fri, Nov 22, 8:11 PM CST
Subject: Strange Line in Aerial Render
FranOnTheEdge ( ) posted Mon, 19 October 2009 at 7:23 AM · edited Wed, 24 July 2024 at 9:27 PM
Hi,
I wanted to render out a material I made for my white egg (with blue mottling)
[okay so I haven't got the mottling to look right on this large 2D image plane, but I'll adjust that when I get the render right.]
My problem is that I have this odd difference in colour on the 2D image plane when  I render from TOP view.
I originally had it just with the Bryce sun, so I turned that off and tried with just IBL, but still got this odd colour difference, now I've just tried with no IBL, no sun, and used a light dome, but I'm still getting an odd distortion at the same place, less colour discrepancy but the distortion is still there.
Even my usual final trick of turning the Atmosphere to Off and the colour to Black, has had no effect on this odd glitch.
I've now also tried rendering with the camera view in case that was it... with no discernable difference.
I'm running out of ideas now.
Help?
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
JeffersonAF ( ) posted Mon, 19 October 2009 at 7:50 AM
You tried to use parametric with symmetric tiling?
FranOnTheEdge ( ) posted Mon, 19 October 2009 at 7:55 AM
Yup.  Still get the glitch.
Fran's Freestuff
kiwi_gg ( ) posted Mon, 19 October 2009 at 12:37 PM
Try turning "underground" off and see if that works
(right hand side tool bar)
Cheers
GG
WHO said Kiwi's can't Fly ?????
FranOnTheEdge ( ) posted Mon, 19 October 2009 at 4:02 PM
Tried that... glitch still there.
Fran's Freestuff
electroglyph ( ) posted Thu, 22 October 2009 at 10:04 PM
I know you turned sunlight off. What about link sun to view?
FranOnTheEdge ( ) posted Fri, 23 October 2009 at 5:57 AM · edited Fri, 23 October 2009 at 6:05 AM
Hang on, I'll take a look...
That too is off, it has no bead in it...
Is that good or bad?
I've tried making the light dome smaller and then larger, this only changes the brightness (obviously) it has no effect on this nasty line.
I'm still stuck.
Fran's Freestuff
electroglyph ( ) posted Fri, 23 October 2009 at 6:36 PM
It should be off. Linking sun to view can cause the camera view to seem brighter when it faces in different directions.
So you are making a 2D texture on a plane? You want to wrap this around your egg model? If the original texture is procedural try changing the mapping. Random might work well for a mottled design.
