Sat, Nov 9, 6:58 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 10:28 pm)
Subject: P7 help Cant find textures
cfpage ( ) posted Mon, 19 October 2009 at 11:14 AM · edited Sat, 09 November 2024 at 6:58 AM
Never had any real problems with P7 and the ones I did I was able to correct with reading post's
or fix my self. Till now.
I had to do a fresh re-install and set up everything like before, main runtime and my other runtimes
so I setup a sceen save it, when I came back to work on it, problem loading texture (can't find it)
even if I save to fig to libary reload, save sceen , re-open same thing. mainly with hair figs,
this never happened before, with the same setup,  before my reformat fresh install. any Ideas ?
Propschick ( ) posted Mon, 19 October 2009 at 11:21 AM
Go to general preferences, library and choose shallow search - see if that works - it should
Ever stop to think, and forget to start again?
hborre ( ) posted Mon, 19 October 2009 at 11:55 AM
Shallow search?  Usually deep search corrects such problems.
Propschick ( ) posted Mon, 19 October 2009 at 12:03 PM
Ahhh I usually test on shallow as deep skips over actual real file calls
hborre ( ) posted Mon, 19 October 2009 at 12:14 PM
OK, just confused by the response.  Thanks for the enlightenment Propschick.
Propschick ( ) posted Mon, 19 October 2009 at 12:15 PM
Glad I could enlighten and remove the confusion =)
cfpage ( ) posted Mon, 19 October 2009 at 1:28 PM
Quote - Go to general preferences, library and choose shallow search - see if that works - it should
I had tried that before,only this time I re-booted pc and seems to be working now, thanks
for the help.
Propschick ( ) posted Mon, 19 October 2009 at 1:50 PM
hope it stays working good for you
