Tue, Feb 4, 8:38 AM CST
Subject: Render Cow is Sick
synergy543 ( ) posted Mon, 19 October 2009 at 3:15 AM · edited Tue, 04 February 2025 at 6:20 AM
 I have an image that renders fine internally but doesn't render properly on the render cows (appears washed out) and I can't figure out why.  I've checked every possible setting I can think of but nothing corrects the problem.
Here is the correct image:
Correct image
And what the cows bring home:
When the cows come home
The scene uses global radiosity and I got a message saying motion blur must be turned on (which it is) and other than that, all settings for the internal render and the cow are identical.  I've also tried many different formats (tga, bmp, tiff) but that didn't change anything.
I can't think of anything else to change or check but I must be missing something.  Also, the render cow time seems to short (23s) whereas the internal render is 2m30s.  So the cows seem to be grazing too quickly before coming home.
Has anyone seen this problem?
I'm also having the same problem rendering other scenes with render cows so its not just this scene.  I just tested with the Vue sample scene "Peaking Through" and got the same problem (no radiosity in that scene).
Any ideas or suggestions?  I've used the render cows before with little problems ever so I'm puzzled why this is happening.
Greg
Tech Info:
Mac OX 10.5 (on all 3 machines)
Vue Infinite 7.40-04 Build 43993 (all cows are current versions)
Global Radiosity - motion blur turned on in render
Crowning ( ) posted Mon, 19 October 2009 at 2:00 PM
There is this post-render-options  pop-up which lets you adjust gamma settings and stuff.
Maybe the settings there are different for internal vs. network render.
I have absolutely no differences between local vs. network renders.
synergy543 ( ) posted Mon, 19 October 2009 at 7:01 PM
 Can you use post effects for network renders?  If so, I wasn't aware of this.  I though post-effects were only available on internal renders to screen.
How do you access post-effects for network renders to disk?
synergy543 ( ) posted Mon, 19 October 2009 at 7:15 PM
 OK, another question....
Is anyone using Render Cows on a Mac successfully with Vue 7.4?
I know its worked well for me with previous versions but could there possibly be a problem now?  Or is it me?
