Blender F.A.Q (Last Updated: 2024 Nov 24 8:44 pm)
So I'm assuming no one can tell me how to change the settings in 2.49a or 2.49b so this stops happening?
There's a Brand spanking new computer running thats maxed out. Only program installed is Blender 2.49b (not even an anti-firus is installed yet) but this still happens!
And it has a new HIS Radeon 4670 HD card in it! Blender should not be doing this.
I would use the 2.50 beta but the scrollwheel does not work in that program and I need to be able to move my views.
Someone PLEASE Help!
Assuming that your copy of Windows 7 is a 64-bit version, why not try this link over at ATI.com? Otherwise, you could check for the 32-bit version.
Also, what you described is not necessarily that you lack a 3D accelerator to properly run Blender, it's that you actually lack the OpenGL driver that Blender is heavily dependent on to run, hence the message. This usually happens if you've recently installed Windows (generally any copy from 98 to recent does this) and it installs a baseline driver that works on your video card, but does not provide any additional functions. The only thing you can currently do, especially if the problem keeps happening, is try to use a driver cleaner to remove any and all drivers for your video card, then reinstall the drivers from either the cards manufacture or ATI's website.
Hope this helps some.
Click Download to see the animation.
Anywho, since I installed Windows 7, I now get the error message "Video Card does not support 3D" when I know it does. The Card didn't change, just the operating system.
Unfortunately, Blender is now doing the above when it starts. Clicking a menu is not a problem, for it works fine, but clicking off of it, and the menu does the same thing. Oh and the actual animation should be twice as slow. :(
Also Blender refuses to see the installed Python as before.
PS: the image is a screenshot from Blender and the animation you see a re-creation I did in Photoshop.
