Sat, Jan 25, 2:39 PM CST
Subject: Lighting question
DocMatter ( ) posted Thu, 19 July 2001 at 9:10 AM ยท edited Sat, 25 January 2025 at 12:01 PM
Is there a way to make an object "invisible" to lights. I have a figure inside of a semi-transparent object (a fogbank) and I want to apply some lights to the figure without affecting the surrounding fog. Is this possible in Poser? My fogbank, by the way, is a cube with a wave-deformer acting on it with the fog transmap applied and the transparency set at max.
atthisstage ( ) posted Thu, 19 July 2001 at 1:53 PM
If I'm understanding the question properly, I doubt you can. But you might try changing the highlight and ambients in the "fog" piece to black and see if that affects the lights hitting it. In theory, they shouldn't affect it at all.
Famine ( ) posted Thu, 19 July 2001 at 10:11 PM
any trans abouve 46% will pass light. or at lest cast shadows through it. If you use a ambiant light for your fog and turn the highlight black you should get good fog that dont change much from lights. watch you trans mapping. Try to keep it at least 46% transparent.
DocMatter ( ) posted Fri, 20 July 2001 at 1:45 PM
Famine-- Your fog looks a hell of a lot better than mine. How did you do that?
Famine ( ) posted Sat, 21 July 2001 at 6:13 AM
when I get a chance monday ill send you a short on how that was done. It dont take long either
