Tue, Dec 24, 11:24 AM CST
Forum Moderators: Staff
Subject: 32 bit Poser on 64 bit Windows7 os
pappy411 ( ) posted Thu, 22 October 2009 at 9:28 AM · edited Tue, 24 December 2024 at 11:21 AM
i guess Poser 5-6-7-&8 are 32 bit apps only.  Will they run normally on a 64 bit windows 7 os?
I am confused on this issue as no mention of 32 bit or 64 bit on Poser 5-6-7-8.  Poser Pro is advertised as 64 bit engine.  Will I have to get Poser Pro if i run a 64 bit os?
thanks for any advice.
Pappy
Lucifer_The_Dark ( ) posted Thu, 22 October 2009 at 9:49 AM
Poser has always been a 32bit program, even Poser 7 Pro is a 32bit program, they work just as happily in 64bit Windows as they do in 32bit Windows.
Windows 7 64Bit
Poser Pro 2010 SR1
pappy411 ( ) posted Thu, 22 October 2009 at 10:03 AM
Thank you Lucifer
markschum ( ) posted Thu, 22 October 2009 at 10:15 AM
A 54 bit OS will run most 32 bit applications with no problems at all and you will get better memory handling.   Poser Pro adds a 64 bit render engine
Lucifer_The_Dark ( ) posted Thu, 22 October 2009 at 10:24 AM
Up till a few weeks ago I was using the Windows 7 64bit Beta & Poser 4-8 work perfectly, I'm now using XP64 & still get good performance out of Poser.
Windows 7 64Bit
Poser Pro 2010 SR1
pappy411 ( ) posted Thu, 22 October 2009 at 10:43 AM
Ahhh!  That is music to my ears.
Khai-J-Bach ( ) posted Thu, 22 October 2009 at 11:39 AM
tried Poser 5,6,7 and Pro on Win7 64 with no problems at all.
JenX ( ) posted Thu, 22 October 2009 at 3:28 PM
I've been using Poser's 6-8 on Windows 7 for months (as well as both the 64 and 32 bit versions of DS) with absolutely no problems :)
Mariny ( ) posted Tue, 17 November 2009 at 2:27 PM
Hi.. Can someone help me??
I tried to open poser 8 in windows 7 64 bit and it will not open.. It says something that it is not compatible??
Lucifer_The_Dark ( ) posted Tue, 17 November 2009 at 2:46 PM
Can you post a screen grab of the error message?
Windows 7 64Bit
Poser Pro 2010 SR1
nruddock ( ) posted Tue, 17 November 2009 at 4:12 PM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2786372
> Quote - Hi.. Can someone help me?? > I tried to open poser 8 in windows 7 64 bit and it will not open.. It says something that it is not compatible??
It's probably what's known as a "side by side configuration error".
Mariny ( ) posted Tue, 17 November 2009 at 5:35 PM
Hi.. I did a "CLEAN INSTALL" FROM WINDOWS CD, AND NOW IT WORKS:-))
