Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:11 am)
With Vista, go to your control panel, system tools, device manager. Find your video card and click on have windows up date driver (must be connected to internet). It takes a while, but if there is an update the OS will find it and install.
With Poser open, get more memory priority to Poser via CTL, Alt, Del will bring up the task manager. You should find Poser.exe working down the list, Right click and pop up box will come up with one item set memory priority. I usually go for above normal.
Hope that helps with your issues. Byron
Anyone else having problems with poser and vista home premium? I have had several times where poser will close for some reaon, and I will get a message saying that windows is looking for a way to fix the problem.
If anyone else has had a problem, and been able to fix the problem, how did they do it? My computer is brand new and is able to handle poser easily since I asked for one that has the memory needed for running poser.
