Blender F.A.Q (Last Updated: 2024 Nov 24 8:44 pm)
Really interesting.
Can't wait to try it out.
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
Try this one from DingTo:
http://www.graphicall.org/builds/builds/showbuild.php?action=show&id=877
His is the only one I test out.
If you still have problems...you may need to install runtime components of Visual C++ libraries.
blender.org has the details there.
Edit: Oops, I see that was the link you downloaded.
I think you may have to install the Visual C++ libraries as detailed at blender.org.
I have never had an issue with this on XP pro sp2 and Blender.
Is that 64bit xp pro?
If so...
Note: This version requires Visual C++ 2008 SP1 Redistribution Package (x64). (about 5MB)
The 64bit release of Blender for Windows is still in a development stage: it doesn't support all possible features yet, like FFMPEG, OpenAL and Quicktime.
If this does not work, then someone else may have an answer...I'm still new at Blender.
Can not think what else is causing this error.
If so...
Well, I dont have 64bit, and I d/loaded 32bit Blender (or I hope so:<). Isn
t the pkg made for 64bit machines? I found sth else:
Microsoft Visual C++ 2008 SP1 Redistributable Package (x86)
http://www.microsoft.com/downloads/details.aspx?familyid=A5C84275-3B97-4AB7-A40D-3802B2AF5FC2&displaylang=en
Microsoft Visual C++ 2005 SP1 Redistributable Package (x86)
http://www.microsoft.com/downloads/details.aspx?familyid=200B2FD9-AE1A-4A14-984D-389C36F85647&displaylang=en
What about these?
Quote - Try deleting the custom default blend file b25.blend(in the .blend folder) and restarting blender.
Hmmm... No .blend fldr, no b25.* file :0 What`s wrong?!
Using http://www.graphicall.org/builds/builds/showbuild.php?action=show&id=877
DO you think a graphics card or its drived could crash an app on start?
Thx. Unfortunately, it repeated so many times I dont think another one would fix the thing. Do you know some other place where I could get B 2.50? Don
t the guys at www.blender.org have some test build repository?
BTW, the zip archive works w/o any error messages, so it seems they have some problem on their server??
Nope, still not working. I must be missing something. Did the controls for the Scroll wheel change?
I'm using the Windows7 Beta (activated)
Scrolling zooms in & out as normal as does pressing it to rotate around the mesh in real-time.
But The Shift + Scroll and the Ctrl + Scroll does Nadda (Nothing at all).
All updates and needed files installed but same issue continues to happen. 2.49b does not do this. Instead it gives me a menu lag (when you hover off of it).
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2782467
This bugs me. The 2.50 beta runs soooooo much smoother then 2.49 and later ever did. Same goes for it's lighting. :(
A new build released today at GraphicAll.org...
http://graphicall.org/builds/builds/showbuild.php?action=show&id=877
Lots of bug fixes.
That's 7 updates this past 2 weeks...thank you DingTo.
