Photography F.A.Q (Last Updated: 2025 Feb 03 6:38 am)
Best way to create shadows is to either draw them in manually, or do fill on separate layers. Using a drop shadow filter puts everything on one layer, so what happens if 35 actions down the line you realize you want to change the direction/colour of the shadow? Ya get screwed... anyhoo, I'll be adding the rest of the shadows and such when I put ito on top of the other pic, however way I'll do it. There are shadows on her face though if ya look...
Here's another way of putting drop shadows in a new layer without using the default shadow effects and eye candy in PS-- 1. select outline of the object 2. create new layer 3. fill in the selection with solid color (gray or black or whatever you want the shadow color to be) 4. go to Effects|Blur|Gaussian Blur and customize the effect 5. play around with the opacity and the position of the shadow. This way if you want to remove the drop shadow or change its color anytime, you may do so without so much hassle. Of course, you guys might know this already. :-)
![file_193806.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_193806.jpg)
This will almost for certain be put into that other file i posted earlier, which I will also post after this. Just a screen shot. Comments, critisms, and christmas money are demanded
