Fri, Nov 22, 7:37 PM CST
Subject: Newbie problem: transparency with imported objects
NanetteTredoux ( ) posted Wed, 04 November 2009 at 12:26 AM · edited Fri, 22 November 2024 at 3:36 PM
I have had Bryce for a while but done nothing fancy with it. I have run into a problem and I am stumped - please help me. I imported an obj file of a plant. The branches are modelled as flat polygons and use transmapped image textures. I have applied the textures using the material lab being careful to tick the "blend transparency option". However, some parts of the plant don't show the proper transparency, others do. I have some branches that look fine, others are black with the image of the texture showing. All branches use the same material. The same object renders fine in Poser 8. I must be doing something wrong in Bryce, but I don't know what. An image of my test render is attached.
Poser 11 Pro, Windows 10
johnyf ( ) posted Wed, 04 November 2009 at 12:40 AM
Most obj. plants are usually made of 2 or 3 parts. Hold down Ctrl and click on the model to see a list of each piece, and then treat each seperately in the mat lab!
Hope this helps!
erosiaart ( ) posted Wed, 04 November 2009 at 2:40 AM
which version of brye? import it thru daz if you have version 6.
NanetteTredoux ( ) posted Wed, 04 November 2009 at 2:54 AM
I have version 6.1, but my Daz studio is version 3 and they don't seem to talk to each other. I'll install an older version of Studio to see if that helps.
erosiaart ( ) posted Wed, 04 November 2009 at 3:26 AM
version 2..
airflamesred ( ) posted Wed, 04 November 2009 at 5:11 AM
You will also need to move the transparency blob into the relevant channel and make sure it is reading the alpha information.
I can do a screen shot later if you need
NanetteTredoux ( ) posted Wed, 04 November 2009 at 5:33 AM
Airflamesred, I would appreciate that very much.
The whole object has only one group, referencing a single image. So I was not able to apply materials separately for the different branches. I don't think that is the problem anyway, otherwise it would not render properly in Poser, which it does.
Daz studio and I are not friends. Perhaps I just haven't spend enough time with it.
airflamesred ( ) posted Thu, 05 November 2009 at 4:19 AM
Hopefully this helps
