Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 23 7:16 pm)
Did you reinstall SR-3? It cures a multitude of sins...
"Oh - the manual says that? I have never read the manual - this must be why."Did you update anything before this started?
I run a similar system, Vista Ultimate 64 with 8 Gig RAM and an Nvidia 9800GT card and Poser 7 and 8 run fine.
I don't render with them though, I use Vue 8 Infinite for that.
Any changes to your system may have had an adverse effect on something, do you have a restore point you can try??
Injustice will be avenged.
Cofiwch Dryweryn.
Well I'm out of ideas, sorry.
Except amybe a clean re-install, that's move your runtime somewhere safe, Uninstall Poser and manually delete the stuff that's left behind, then re-install and include SR3 and then put your saved runtime in place of the one Poser puts in!
That's my last idea!! [LOL].
Cofiwch Dryweryn.
Poser has an odd habit of not running the same even on two different computers with the same OS, RAM amount, graphics card, and CPU.
Quote - I don't know how you guys stand this software.
Works just fine for me, with only the occasional, non-reproducible errors. Although that might be because I'm running XP.
________________________________________________________________
If you're joking that's just cruel, but if you're being sarcastic, that's even worse.
Maybe you should UNCHECK "Use external binary morph targets" found under Edit / General preferences / Misc tab .That gave me lots of headaches too .
Alice's and
GND4's Tailor !
Check my free clothing
fits : www.alizea3d.com
Okay, I'm not sure what I did, but I seem to have a fairly reliable scene where I can perform my cloth dynamics. Maybe it was when I tried hopping on one leg and spinning around while chanting the lyrics to "Inna Gadda Da Vida". (yeah, like anyone has a clue what that song was...)
Anyway, my biggest remaining problem is that Poser 7 seems to have a problem importing .obj files. Even if those files open fine in other apps. I'd say maybe 50% of the time, Poser will freeze when it gets to about 100% of the file import. Only way to recover is kill Poser from the Task Manager.
I've done everything suggested above in this thread, so I'm at a loss. BTW, I also tried converting to a 3DS file and importing, with similar results. Although just before it freezes, the object appears in the scene, which doesn't happen with the .obj version.
Anyone? Thanks
Quote - > Quote - Did you reinstall SR-3? It cures a multitude of sins...
yup I installed it, and the adultery, sloth and gluttony went away.....
It doubled the lust, though... :lol:
"Oh - the manual says that? I have never read the manual - this must be why."Attached Link: http://www.renderosity.com/mod/forumpro/media/folder_9/file_403828.jpg
I do remember havings problems like constant crashing when I first installed P7. Turns out it was fixed by messing with the preview tab in the render settings (I do apologize in advance if I'm very vague. I'm at Uni and my laptop can't handle Poser). The link above is what I found to work for me.Well, FWIW (for what it's worth...), I cleaned out all Poser 7 for the third time, and loaded only 7.02 (?) right off the disc, and things are lookin' up. I'm loading .obj files left and right and it's working fine. I'm afraid to install SR3, and since it's working now I don't think I will unless I start getting other problems.
Anyway, thanks to all for the help. I've no clue what the problem was, but those gremlins seem to have moved on...
Okay, I've tried everything and I'm about to give up. Trying to use Poser 7 (I've used Poser very sporadically since P4...) on a Vista 64 bit system with 8GB memory, latest system drivers, latest P7 SP3. It freezes when I delete the default Simon in the default scene. Every single time. Also freezes at other times, such as when deleting .obj's.
And I've done everything. Reinstalled P7 onto the D: drive because Poser is so freakin' stupid. Using Sreed instead of OGL. Running P7 as Administrator. Brought down undo levels to 10. Clear cache at the start of the session.
I only use Poser because it does cloth simulations with Poser figures, but unless someone has some ideas on how to resolve this nonsense, it's Blender time.
Anyone? Thanks.
