Mon, Feb 10, 1:26 PM CST
Subject: Rendering with no lighting but not getting a black figure?
GroZZleR ( ) posted Wed, 04 November 2009 at 5:51 PM · edited Mon, 10 February 2025 at 1:08 PM
Hey all,
Is there a way to render an image without lighting but still have the figure be coloured?  When I turn off all the lights, the figure becomes completely black.  I'm trying to render some game sprites and lighting would ruin the way the figure looks while rotated.
For example:  If I render the figure from overhead, when I rotate the sprite, the shadows move with the sprite despite the fact the sprite hasn't moved through the scene.
I can provide a picture if that's not very clear.
Thanks guys!
markschum ( ) posted Wed, 04 November 2009 at 6:25 PM
Turn off shadows for the lights.
I render preview animations using three spotlights , all ligt grey color, spaced at 120 degree pointing at the center where my figure is rotating. Positioned slightly above and pointing down about 30 degrees. Spotlight start angle 70 , end angle 140 .
With this setup you will still get some small specular changes as the model is turned.
With Poser 7 or 8 you could use Image based lights or GI.
Kalypso ( ) posted Thu, 05 November 2009 at 12:52 AM
Site Admin Online Now!
In Poser 8 load a skydome prop and delete the lights.   Make sure you choose IDL in your render settings and adjust tone mapping to your liking.  You will get a globally illuminated render.
You can use Bagginsbill's environment sphere found here:  http://sites.google.com/site/bagginsbill/free-stuff
