Vue F.A.Q (Last Updated: 2024 Sep 17 9:46 am)
That's a phenomenon known as light leak. That happens with radiosity. I'm not sure if you can call it a bug, it's a secondary effect of the radiosity engine in Vue. It's not directly related with your lighting. It's not related with Poser characters either, it can happen with anything.
There are several things that influence this effect. From the top of my mind, here's some:
a) if your characters have some self luminosity, even if small, this effect increases. SkinVue applies a certain luminosity to skin, for example, to fake SSS.
b) if you have very thin objects, like planes, that also increases the effect.
c) if you have radiosity gain, it also increases
I'm sure there are more, but I can't remember now.
Some ways to decrease it, other than counter-acting the effects above, again from top of mind, not an exaustive list:
Hope that helps.
I can't say HOW long I've searched for the hidden 'under-the-skirt' light in this image:
www.renderosity.com/mod/gallery/index.php
Thank you all for that information.
I set Ambient down to 0% for both torso skin and hand skin and the result is much better.
(see attached image)
You will notice that the effect is not completely gone; there is still some glow around the thumb and the little finger. I wonder if there is another variable somewhere that adds Ambient or Luminous light?
Thanks again for your help; this is one step further towards solving this problem.
Radiosity gain zero does not mean there's no radiosity. If you want to test it, do this: apply a solid color to the surface near the hand and see that the fingers become slightly tinted near the surface, with that same color, from photons bouncing from that surface to the hand.
The radiosity gain simply enhances this effect.
