They ONLY fit the figure they are made for ....
So V4 stuff fits V4 unless it has mophs to fit other series 4 figures like AIKO4 and TG4
Non DAZ figure cloths will fit Poser figures and vise versa..
If you like you can try the wardrobe wizzard in P8 to make em fit ..but thats not as simple as it sounds
BC
IF YOU WANT TO CONTACT BAR-CODE SENT A PM to 26FAHRENHEIT "same person"
Chris
Not a problem. :)
You'll need to get the Wardrobe Wizard support files for V4. Either click the "Convert" button to bring up the main Wardrobe Wizard window and then click the "More Figures" button, bottom left. Or use this direct link:-
http://www.philc.net/store_WW_Extra_Figs.php
Hope that helps.
To be sure that I have understood you correctly may I please ask, what do you mean by the Python Script window?
Are you using Poser 8?
Poser 8 includes Wardrobe Wizard 2
If you click the Poser menu Window > Python scripts do you get a pop up window appearing containing ten buttons?
Is the first button noted as "Wardrobe Wizard"?
If so and you click on it does the button list change so that the first button now says "Convert..."?
If you click on the Convert button does the main Wardrobe Wizard window appear?
Does V4 & V41 appear in the two scrollable lists labeled "Convert from" and "Convert to"?
The lists are arranged alphabetically.
You may need to close then restart Poser for it to recognize new files.
If V4, V41 does not appear it will indicate that you have not installed the files correctly. The files are supplied in a zip archive. The instructions that came with the download indicated that the extracted files should be placed in the folder Poser 8:Runtime:Python:poserScripts:PhilC:Wardrobe Wizard P8:data
A video overview of how to use Wardrobe Wizard may be found at:-
http://www.philc.net/WW2_plugin_overview.php
Full instructions are in the Poser manual.
Thanks.
I figured out the problem
Your files did not extract when I extracted them to the data file, it just moved them there.
So I unzipped the files in place and that did work either because it created a folder in the data file.
I copied the files in the folder into the data file and now it shows
I'll read the php and see if I can figure it out from there
I have the general idea of Wardrobe Wizard figured out relative to conversion, but the shoe comes into the scene rotated 45 degs up. The rotate morphs just move the shoe up and down as if the translate morphs were used, the translate morphs of course do the same thing. If I manually rotate to get the shoe level on the ground the shoe rotates around the very bottom tip of the heel bending and distorting the heel. Any ideas
I sent it to the only pcook address, and btw the one that says primary address listed on the website. I assumed you would know this address and was trying to maintain your privacy
from Charles Dog charlespdog@gmail.com to pcook@philc.net
date Tue, Nov 17, 2009 at 4:26 PM subject Hi Heels mailed-by gmail.com
hide details Nov 17 (3 days ago)
Attached are the files, have no idea what IK chains are
Your Friend,
Paul
2 attachments — Download all attachments
V4 MT Pump L.cr2
4204K Download V4 MT Pump L.rsr
20K Download
Please tell me where to email the files..........Is this proper to maintain a personal discussion on this site?
I've double checked but no email found. Could you please resend, this time to philc_designs@yahoo.com
Thanks.
I bought some shoes for V4 and would like to attach them to P8 Alyson. Is there some easy way to do this? I notice the shoes show up as a figure so I have been trying to move them in place using the parameter dials, difficult to say the least.
Also is there some way to disable body parts so that they are not taking up memory so it is easier/smoother to move the feet and shoes.
Done properly will these shoes move with Alyson poses? If so how do I do that?
Thanks
