Fri, Jan 3, 2:59 PM CST
Subject: Poser render ( every versions )
Anthanasius ( ) posted Mon, 16 November 2009 at 12:08 PM · edited Fri, 03 January 2025 at 2:55 PM
Everyone know how to have the full render in the preview window ?
Rendering for exemple a 640x480 in a 320x40 window ... I know it not speed the render lol, it's just to have the ability to stop the render if what i want to see is done ... Cause the render status is "stupid" some time the progress bar is at the end and not the render .
Génération mobiles Le Forum / Le Site
aeilkema ( ) posted Mon, 16 November 2009 at 12:13 PM
The only way to get the full render in the preview window is making them both the same size. Don't think this can be achieved otherwise.
Food for thought.....
NoelCan ( ) posted Mon, 16 November 2009 at 12:59 PM
Use the Render Selection Button (The one to the right of the Render).  Select the area You wish to view..
nruddock ( ) posted Mon, 16 November 2009 at 1:44 PM
For version upto P8 (provided you've got enough scrren resolution) you can just set the document window to the size (or larger) of your render.
For P8 you'll need to undock and float the document window before you can set a specific size.
If the document window is larger than specified render size, you'll get the "Production Frame" displayed to show you what will actually be in the render.
If you're rendering size is too large, you won't be able to fit the whole thing in the Render window, and you'll have to pan the image to see areas that are off-screen.
raven ( ) posted Mon, 16 November 2009 at 2:13 PM · edited Mon, 16 November 2009 at 2:17 PM
Click on the Render tab on the document window, and select Half instead of Full and your render will then be half size, which should then fit in your preview window fully. I tested it and it works. I set my render dimensions to double my preview window and select Half on the render tab and the whole render appeared in the preview window.
That should work from Poser 6 upwards.
Anthanasius ( ) posted Mon, 16 November 2009 at 3:22 PM
Thx all
