Hi To get her to work you need to create some morphs that Mimic recognizes... Zero out all of your head parameter dials Set the EyeBlinkR dial to "1" Make sure the head is selected Go to the menu select "Object" then "Spawn Morph Target" Name the morph "Blink Right" Do the same thing for "EyeBlinkL" and name the morph "Blink Left" I don't remember for sure right now, but you might have to spawn a morph target for "OpenLips" ....like this no space. If the morphs aren't named the same as the P4 morphs, Mimic doesn't recognize them. I wish they would update the program so you could add or delete morphs that it uses. Hope this helps some Ed
How can I get Victoria 2 to respond to the blink information given out by Mimic? I see that her eye morphs are called EyeBlinkR and L ... what
s the correct method of renaming them so that the movements are picked up? I just tried a simple rename by double clicking, but it doesn
t seem to work.
