Sun, Jan 26, 1:41 AM CST
Subject: Vicky 2 not blinking blinking - Mimic
polartech ( ) posted Sun, 22 July 2001 at 3:24 PM ยท edited Sun, 26 January 2025 at 1:36 AM
How can I get Victoria 2 to respond to the blink information given out by Mimic? I see that her eye morphs are called EyeBlinkR and L ... whats the correct method of renaming them so that the movements are picked up? I just tried a simple rename by double clicking, but it doesnt seem to work.
shadowcat ( ) posted Sun, 22 July 2001 at 10:32 PM
morph manager might work?
EdW ( ) posted Mon, 23 July 2001 at 1:24 AM
Hi To get her to work you need to create some morphs that Mimic recognizes... Zero out all of your head parameter dials Set the EyeBlinkR dial to "1" Make sure the head is selected Go to the menu select "Object" then "Spawn Morph Target" Name the morph "Blink Right" Do the same thing for "EyeBlinkL" and name the morph "Blink Left" I don't remember for sure right now, but you might have to spawn a morph target for "OpenLips" ....like this no space. If the morphs aren't named the same as the P4 morphs, Mimic doesn't recognize them. I wish they would update the program so you could add or delete morphs that it uses. Hope this helps some Ed
polartech ( ) posted Mon, 23 July 2001 at 1:40 AM
Thats brilliant - thanks very much. Yes, youd think that this would have been an option by now, wouldnt you! I think Ill drop a mail to the Lipsinc folks. Cheers...
shadowcat ( ) posted Mon, 23 July 2001 at 12:35 PM
I checked, you can simply rename the existing morphs using morph manager. load up your vicky 2 .cr2, locate the morph, right click and rename.
polartech ( ) posted Mon, 23 July 2001 at 1:38 PM
Superb... thanks shadowcat ;-) Hope this thread serves to help others experiencing this same problem.
hpalan ( ) posted Thu, 26 July 2001 at 12:30 AM
I emailed the Mimic people and got a real easy answer. Use Notepad to edit the PZ2 file that mimic creates. Rename the "Blink Right" to "EyeBlinkR" and the same for the left eye and save it. It's a breeze! Henry
