Thu, Nov 14, 12:41 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: conformin problems
fairyfantastic ( ) posted Sun, 22 November 2009 at 5:33 PM · edited Thu, 14 November 2024 at 12:38 AM
hi all im trying my hand at clothing i dont have programs to help in comformin so im groupin in modelin program welli managed to model outfit import to poser get to set up room and wen i pose tht werei have problem the problem is  wen i pose  wen standin its wen  sitting down i was wonderin is some one  had advice on solving this thnks paulaxx
Apple_UK ( ) posted Sun, 22 November 2009 at 7:07 PM
 I can't help, but looking forward to other replies because it's a problem I have each time I tried to make clothing in the setup room
DarkEdge ( ) posted Sun, 22 November 2009 at 7:15 PM
Introduce yourself to the Inner Mat Spheres.
markschum ( ) posted Sun, 22 November 2009 at 10:45 PM
If you have it properly grouped and have used a donor cr2 the you need to look at the inclusion/exclusion zones or the spherical falloff zones.
chriscox ( ) posted Sun, 22 November 2009 at 11:17 PM · edited Sun, 22 November 2009 at 11:18 PM
Skirts and dresses are notorious for being difficult to rig.  One of the classic tricks is to group everything below the abdomen as the hip and to add body handles to help posing.
With body handles you can pose the "thighs" in the dress back to an unbent position and then bend the dress into a sitting position with a body handle.
PhilC has some tutorials on added body handles, though I don't know how good they are as they use the setup room which I never use.  He also has tutorials on rigging and joint parameters.
http://www.philc.net/tutorialsIndex.php
Chris Cox
fairyfantastic ( ) posted Mon, 23 November 2009 at 1:50 AM
Quote - Introduce yourself to the Inner Mat Spheres.
umm wat r thm hun
mark i havent used a doner cr2
chriseverything is  groupedas the hip hun i have seenphils tutbut i can get so far thn wen get to addeing bone n savin n namin im stuck
Anthanasius ( ) posted Mon, 23 November 2009 at 3:08 AM
Turn it into dynamic, it's the most simple and the most realistic !
Génération mobiles Le Forum / Le Site
fairyfantastic ( ) posted Mon, 23 November 2009 at 3:10 AM
how do i do tht nevr worked with dynamics b4
RobynsVeil ( ) posted Mon, 23 November 2009 at 5:19 AM · edited Mon, 23 November 2009 at 5:21 AM
You've entered a somewhat complex area, Paula. Clothing needs a number of things checked in order for it to work in Poser:
UV mapping
No duplicate verts
polygons all facing the right way (out)
Other, more experienced modellers will most certainly find other things to add to this list. Those were just the bug-a-boos I faced.
Quite frankly, I never did get the setup room to work properly for me. However, you might try PhilC's Obj2Cr2 utility: it takes the pain out of making conforming clothing. I wrote a quick and dirty little thingie on it here:
www.renderosity.com/mod/tutorial/index.php
which has a link to PhilC's brilliant tool.
Good luck with it, sweetie...
Metaphor of Chooks
fairyfantastic ( ) posted Mon, 23 November 2009 at 3:48 PM
thnks robyn but atmoment with christmas round corner budget low cant get phils programs so will have to waitto get  but it wont stop me making  clothes but if i can do it  with out it would be a bounus
chriscox ( ) posted Mon, 23 November 2009 at 4:04 PM · edited Mon, 23 November 2009 at 4:06 PM
PhilC's site also have tutorials on general rigging and joint parameters.
There are also a couple of fairly basic tutorials at 3D Menagerie http://www.3dmenagerie.com/ look for tutorial in the Goodies section.  One tutorial gose over the basics of Joint Parameters such as the Inner and Outer MatSpheres, which DarkEdge and markschum refer to.  There is also another tutorial "Painlessly Easy Conforming Clothes" which outlines the Donor CR2 method for making conforming clothes.  For Victoria 4 there is a "V4 Dev Foundation" figure that can be used as a starting point for making clothing figures.
BTW if you have Wardrobe Wizard it can be used to make conforming figures and will even add body handles for dresses and skirts.
Chris Cox
fairyfantastic ( ) posted Mon, 23 November 2009 at 4:07 PM
thnkschris ill have a browse see how i get  on
DarkEdge ( ) posted Mon, 23 November 2009 at 6:58 PM
there is also this, a video tutorial walking through every step of the way. ;wink:
www.contentparadise.com/productDetails.aspx
fairyfantastic ( ) posted Tue, 24 November 2009 at 1:33 AM
thnks dark edge :)
