Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 7:14 pm)
above I just quickly loaded V4 and I put a smith micro Sydney G2 tank top on her and stretched the top over her boobs with a dynamic cloth sim.
If you do not mind ending up with a piece of dynamic clothing instead of conforming - you will prob get the best real stretched look for your characters dimensions doing it in the cloth room.
______________________
"When you have to shoot ...
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
http://www.renderosity.com/homepage.php?page=3&userid=580115
this might hug the shape of her breasts a little more than you are looking for , but all you have to do is tweak the damping and air damping settings , as I said, you can get many different stretched looks. if you turn down the fold resistance and shear resistance you will get nice horizontal ripples inbetween the breasts like the cloth is straining .
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
Thanks for your reply, santicor :) I don't have a lot of experience using the cloth room, but I am trying a few tutorials that I've come across. I guess I know just enough about poser to do a few things.
I was hoping that somebody had a morph that would do roughly the same thing, because I'm struggling with the cloth room. I've tried magnets, but with bad results.
xan
I see. I understand - I wasn't sure if you would find a good morph, so i suggested cloth room.
Sorry i do not own the V4 body suit or else i could make a good morph target for you ... using W3D and maybe cloth room. A morph target to apply to it would preserve the clothes as conforming, as that is what you are looking for.
Good luck.
S
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
Attached Link: http://www.morphography.uk.vu/dleztop.html
V3's "Spandex" morph should do the job - I used it in my EZ Top freebie. I don't know if V4 has the same morph off the top of my head, but something similar has been there since the days of Posette so I'd be surprised if there wasn't one. They're intended for making skintight superhero costumes as the name implies.It's hard to see a great difference in the attached image, but there is.
I uploaded it to the Rendo Free area, it should be approved and posted soon.
I hope this proves useful to somebody.
The V4 Bodysuit chest spandex morph is better than my homemade one. But how to get it into Vicky? I tried isolating it -- deleting all morphs in the bodysuit except for that one and spawning an injection morph. But nothing happened when I injected it into Vicky. I confess I don't know everything about injected morphs, so can't explain why this doesn't work. Maybe only morphs that are created in V4 can be injected into V4.
I can 't see a chest spandex morph in the Basicwear sport bra or bikini top.
Your morph is the only way to get a spandex morph inside Vickie, you can't transfer the bodysuit one over. How did you do your morph? If it was with magnets, then you could save the magnet and then use that on different clothing items to make a spandex morph in the clothing.
I showed the bodysuit morph as that was what the original poster was asking about and mentioned the sports bra in case they wanted a clothing item rather than a morph, but if a morph is needed, yours looks fine.
I used P8's morphing tool to "sculpt" her breasts into a sort of smoothed, bridged chest. Then I deleted every morph in her body except for my spandex one and one of the unused PBM channels, in this case #11. Then I used the free Spawn Character script to create the injection morph in Channel 11 and saved it to the Pose library.
This generated INJ and REM icons in the Pose Library (it doesn't generate PNGs, so I did a render to make my own). Since I deleted all other morphs before spawning the injection morph, the only thing it does to Vicky is add a spandex effect to her chest, which can be dialed to zero when unneeded.
It's usefulness is pretty much limited to the stock V4 chest. Make any change to her breasts, or use a morphed character, and the spandex morph starts to look either too little or too much. Sorry about that, it's the best I could do with my limited skills.
I can't imagine trying to do this with magnets. Sure, you could use magnets to drag her breasts together, sort of like the cleavage morph, but you can't use magnets to make a nice smooth bridge between them. At least, I don't know how.
Rendo seems to be up to their armpits (or breasts) in Christmas submissions for the free section, so it might be awhile before it posts.
It can be done with mags but it would be an incredible amount of work requiring an incredible amount of patience.
If you told me i had to do it with mags I would select body part chest and start to create sub polygon groups zones in between her boobs which got progessively bigger and bigger until you got to about the 5th or 6th material zone which would have its outermost diameter at her nipples.
Then i would create a series of magnets, progressively applied to each polygoon group as the groups get larger and larger - ( create magnet and apply the magnet zone to the custom polygon groups) and pull the mag +Z
The real answer is not magnets - it is an outside modeling program such as W3D where you can manipulate single verticies in a very hands-on fashion
Piece of cake - I will work on one.
You are interested in V 4.2???
and what boob morphs do you want her boobs to have before the shirt gets put on ,
or do you want it for default V4.2 boobs ???
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
Quote - The real answer is not magnets - it is an outside modeling program such as W3D where you can manipulate single verticies in a very hands-on fashion
That's exactly what I did with Poser 8's morph tool, which I admit is not the most precise or powerful tool to use on vertices. I'm sure my effort can be improved upon... go for it. I will be glad to trade mine for a better one. See if you can make it look like the one in V4 Bodysuit, as seen above.
By the way, I think there IS a way to get the Chest Spandex morph from the V4 Bodysuit into V4 herself, I just haven't figured it out. I am able to inject spawned morphs into Vicky, and was able to inject her with Chest Spandex... only nothing happens when the dial is put to 1.
your work above is awesome imax i did not concentrate on the thread enough to realize that you just banged out a great morph.
as far as the morph tool .....I am scared of the Poser morph tool
very unstable IMO
crashes me in P7 constantly.
BTW! .....
funny thing about V4.2s chest and abdomen parts going in and out of W3D - they come out of W3d into Poser transed up on Y axis for some reason.
ca't use what i did so far -
hmmm..
this is with an original export from P7 competely zeroed, dropped to floor etc.
that's weird.
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
BTW if you could bridge polys in a modeling program and keep your poly count accurate for Poser - that would be a watershed discovery.
Cuz what them hooters need is to be bridged.
Happy Thanksgivin I am going to work on a boob tshirt .....and get the stuffing prepped for tomorrow
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
Attached Link: My V4 chest spandex morph is up in the Free Section. Click this to go there.
Thanks for your kind words, santicor. You are correct that Poser's morph tool is not all that great, or all that stable in terms of painting morphs accurately, but I'm not having a crashing problem in P8, the Mac version.But the real problem is that Vicky's vertices are kinda spaced out on her breasts (outside the nipple region) so it's hard to get exactly what you want with the morph tool, or to do really fine mesh work. Thus I can't re-create exactly what the V4 Body suit's spandex morph does. It's painstaking, and not for everybody.
Still it's better than nothing if you don't want Vicky's 2nd-skin shirt to cling like paint to her in-between-breasts zone.
I realized that in order to create any shape I want in a mesh that is restrictive (wont line up edge loops etcx the way that I need them) , i have to push the mesh from the inside out with an expansion type cloth sim, yes the dreaded cloth sim,,BUT- this way the object that I end up with can be a morph target for a jointed actor.
hooray
this can do a lot -
I'm workin on this "stretched shirt" morph for V4 chest and the progress is good , and I have not at all changed the general arrangement of the verticies.
But right now I have to go to bed I am having guests for Turkey Day tomorrow.
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
I had an epiphany, too. The reason that the V4 Bodysuit chest spandex morph does nothing when injected into Vicky is that they have different meshes. The bodysuit's mesh is finer, which allows for all those creases, folds and seams. So that morph is pushing and pulling extra vertices that don't exist in Vicky. Duh.
Now if it were possible to select part of Vicky and increase the vertices... Of course then any morph made from that would only work for the person with the altered Vicky.Useless to the general population. Never mind!
Good luck to Santicor in his pursuit of a better chest spandex. At the moment mine is adequate, but not that useful for boobs that are significantly blown up, deflated or moved around.
There probably needs to be a separate morph (like the gravity morphs) for both V4 and her morphing clothes. Something that creates a "shelf" where the cleavage can be modified.
Though the bodysuit chest spandex dial helps, it doesn't really behave like a real spandex top...especially with larger breast sizes.
The best example I can give is what petercotton does with Power Girl. I think he mostly uses A3, and he told me that a friend of his made a panel from the A3 frame, then he modifies each character with Maya.
http://petercotton.deviantart.com/art/Powergirl-Shiny-138388608
I would LOVE to know how to do this stuff on my own, but don't really know where to begin. The funny thing with Poser is the more you know, the more you know that you don't know.
I'll just keep making anaglyphs as I learn how to do other things :)
xan
http://xanaman.deviantart.com/
petercotton made a cute powergirl ! -
here's mine :
http://www.renderosity.com/mod/gallery/index.php?image_id=1931480&user_id=580115&np&np
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
Hi imax24
In my original post, I wanted to know if there was a morph for the bodysuit that would give the effect of material being stretched across the chest. The bodysuit comes with a chest spandex dial, but it never looks quite right, especially with larger breast sizes.
A good body morph for V4 (and others) would be much appreciated and is definitely a good idea since there are a lot of second skin textures out there, but I was originally asking about the bodysuit. Of course, any help and input is much appreciated :)
thanks
xan
But unless I'm confused, we were talking about how to get that spandex effect in Vicky
Yeah i went OT.... i was showing my powergirl based on the SG2 base figure
nothing to do with solving Xanaman's OP.
I just showed it cuz the subject of Powergirl came up.
BTW my Powergirl suit was done in cloth room, which is counter to the morph discussion we have been having - but once again - cloth sim solves everything.
take it for what you will
so this morning i made a morph for V4.2 that looks like stretched fabric between breasts - but only it only works on the default breast shape -
someone mentioned this issue earlier in the thread -
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
I guess a tight shirt morph could be made for every" morphs ++" morph individualy , with said ++ morph set to "1"
I could make one for
"breasts large"
a diffeent one for "breasts implant"
a different one for "breasts diameter",
etc.
and then you would have to apply the "tight shirt" morph of matching name
"tight shirt breasts large, or "tight shirt breasts implant" to the same value as the size morph that you have applied
this would be a clean, but tedious, way of always having a good stretched shirt morph avaiulable no matter your config of breasts ++ morphs.
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
No you would use morphing clothes to apply any morph for V4.2 to any clothing for V4.2.
I actually am going to try to make one scaleable morph that has the boobs bridged and looks right at all different dial values .
i dont think this is going to be easy.
thinking ahead without looking into it completely yet -
i think a "flatten chest" morph that basically makes her boobs non existant would have to be applied first,
then a bridged boob morph could be applied that looks corect at all scales.
her chest mesh is pretty uncomplicated so her breasts might be able to be "nuetralized" to look like she has zero boobs in her default mesh- that would be the first moroh you need to apply
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
Morphing Clothes is a Windows-only utility, so won't do me any good on my Mac. I'll be interested to see the scalable V4.2 morph, though, to see if I can use it for Vicky for 2nd skins.I have my doubts due to the way vertices are arranged in Vicky's middle chest area, but I hope you can do better than I did. Good luck.
we are totally on the same page -
that area in the middle of the breasts will be hard to deal with .
that's why i think I have to get her truly flat chested WITHOUT over-congesting those verticies in the middle in the process . if that can be done, i am off to a good start ...... and a scalable bridged breast shape can be applied to this flat chest, i hope.
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
One of the problems I have with a lot of the Poser clothing is that it looks painted on no matter what I do to it. Is there a morph for the V4 bodysuit (or V3) that gives the appearance of material being stretched across the breasts?
Also, anybody know of a good breast morph for the look of an athletic bra?
Please forgive my photoshoping, but it illustrates what I'm talking about.
Thanks,
xan
