Hm. Do you have Poser on an external drive?
I don't really understand what's happening here. You say all figures are reset to default and at the same time you say they don't show up?
Could you show an example? With a pic of a scene before and after saving and reopening it?
A poser scene saved from Poser is a .pz3 or pzz file. Its a single file unless you use external binary morphs. (not suggested)
That is saved from the poser File menu , save or save as.
anything else like figure,pose, material is a subset of the scene file.
The scene file should be complete in itself, only referencing geometry or image files , everything else should be in the pz3.
What Darkedge asked too.
Hmmm, that content file doesn't show up when I save a scene...not sure what it is.
Still trying to eliminate possibilities, do you have an older version of Poser installed on the same computer and are you trying to open a saved scene from that version with P8?
Or...did you make and save the scene fresh within P8?
Have you installed the SR2 for P8?
Poser 8 needs it's SR's.
There is one niggle I have noticed w/Poser8 (at least on my rig) that affects/involves other versions. I have PoserPro installed on the same computer and have noticed that the FBM for Simon cease to work in PP but they will work in P8.
I don't know if maybe you are experiencing something akin to this.
Sorry that I can't be of more help.
I also am mystified by this talk of a "content file". What file extension do these content files have? Is this a static scene or an animation?
I use P6 and when I save a scene I only get a pz3 file, unless "Use external binary morph targets" is used, and I recommend not using that option.
The problem sounds a lot like the pz3 files are getting corrupted on save. I have had that happen on the very odd occasion, but it should not happen on a regular basis. Perhaps the cr2 for figure you are using (or some other item in the scene) is corrupt, and this is causing a problem with any scenes it is used in. That is the only thing I can think of of the top of my head.
For some reason every time I save a scenet poser doesn't save a content file with it. What's happening is when I try to reopen the scene all figures are reset to default and no props or figures show up in navigation menu.
