Mon, Jan 6, 3:54 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 05 11:51 pm)
Subject: Help!
Dirtylooks ( ) posted Sat, 28 November 2009 at 4:35 PM · edited Mon, 06 January 2025 at 3:47 AM
For some reason every time I save a scenet poser doesn't save a content file with it. What's happening is when I try to reopen the scene all figures are reset to default and no props or figures show up in navigation menu.
shuy ( ) posted Sat, 28 November 2009 at 5:28 PM
Did you checked all animation frames?
TrekkieGrrrl ( ) posted Sat, 28 November 2009 at 8:26 PM
Hm. Do you have Poser on an external drive?
I don't really understand what's happening here. You say all figures are reset to default and at the same time you say they don't show up?
Could you show an example? With a pic of a scene before and after saving and reopening it?
Dirtylooks ( ) posted Sat, 28 November 2009 at 10:13 PM
I will try to give you the best example I can. Here is the image I saved of the scene I was working on.
Dirtylooks ( ) posted Sat, 28 November 2009 at 10:14 PM
And then when I go back into a scene to work on it some more i get this. Without the lighting though.
Dirtylooks ( ) posted Sat, 28 November 2009 at 10:15 PM
And then finally I can't even find the figures or props in the drop down list to repose them.
DarkEdge ( ) posted Sat, 28 November 2009 at 10:41 PM
What version of Poser are you using and verify that you are saving as a pz3 file.
Under Edit/GeneralPreferences/Misc is UseExternalBinaryMorphTargets checked or unchecked?
Dirtylooks ( ) posted Sat, 28 November 2009 at 10:52 PM
I'm using poser 8, yes I am saving as pz3. and UseExternalBinaryMorphTargets is unchecked. I have noticed that when I save Most of the time there are two files a scene file and a content file?
markschum ( ) posted Sat, 28 November 2009 at 10:57 PM
A poser scene saved from Poser is a .pz3 or pzz file. Its a single file unless you use external binary morphs. (not suggested)
That is saved from the poser File menu , save or save as.
anything else like figure,pose, material is a subset of the scene file.
The scene file should be complete in itself, only referencing geometry or image files , everything else should be in the pz3.
What Darkedge asked too.
DarkEdge ( ) posted Sat, 28 November 2009 at 11:00 PM
Hmmm, that content file doesn't show up when I save a scene...not sure what it is.
Still trying to eliminate possibilities, do you have an older version of Poser installed on the same computer and are you trying to open a saved scene from that version with P8?
Or...did you make and save the scene fresh within P8?
Have you installed the SR2 for P8?
Dirtylooks ( ) posted Sat, 28 November 2009 at 11:16 PM
I do have an older version (7) installed, but it is a new scene. Save with poser 8. I do not have SR2 which I am downloading now.
DarkEdge ( ) posted Sat, 28 November 2009 at 11:21 PM
Poser 8 needs it's SR's.
There is one niggle I have noticed w/Poser8 (at least on my rig) that affects/involves other versions. I have PoserPro installed on the same computer and have noticed that the FBM for Simon cease to work in PP but they will work in P8.
I don't know if maybe you are experiencing something akin to this.
Sorry that I can't be of more help.
Dirtylooks ( ) posted Sat, 28 November 2009 at 11:29 PM
I appreciate all you have done. It has become very frustrating to me as I have had this same thing happen now with 6 different scenes. I don't get while my figures are in my window but not in my figure list. Thank you again.
lesbentley ( ) posted Sun, 29 November 2009 at 7:31 AM · edited Sun, 29 November 2009 at 7:38 AM
I also am mystified by this talk of a "content file". What file extension do these content files have? Is this a static scene or an animation?
I use P6 and when I save a scene I only get a pz3 file, unless "Use external binary morph targets" is used, and I recommend  not using that option.
The problem sounds a lot like the pz3 files are getting corrupted on save. I have had that happen on the very odd occasion, but it should not happen on a regular basis. Perhaps the cr2 for figure you are using (or some other item in the scene) is corrupt, and this is causing a problem with any scenes it is used in. That is the only thing I can think of of the top of my head.
Dizzi ( ) posted Sun, 29 November 2009 at 8:27 AM
Well, that it's probably because, Explorer shows "PoserScene" as type for pz3 files and "PoserContent" for pmd files. So PMDs seem to be turned on, explaining what happens to the scenes.
DarkEdge ( ) posted Sun, 29 November 2009 at 8:43 AM
PMD files are the BinaryMorphs I was talking about earlier. Edit/Preferences/Misc to turn them off.
A lot of peps don't like the PMD files but they do work for me in character creation, but that is the only time I turn them on, otherwise they are turned off.
