Thu, Nov 28, 4:43 PM CST
Subject: Blender nodes that work with VSS?
dasquid ( ) posted Sat, 05 December 2009 at 7:26 AM · edited Thu, 28 November 2024 at 4:32 PM
Ok What I am trying to so is this.
I did this render the other day and did not use VSS because i was in a hurry and didn't want to do all the node wrangling required to get the blender node into the mix along with the scar map.
http://www.renderosity.com/mod/gallery/index.php?image_id=1984300
Now I have  decided to go back and try the same character with a few tweaks and using VSS.
I get the above pictured render in this thread. As you can see the displacement works fine. The problem is I am wanting the scars to be white or at least paler than normal skin tone. But with the VSS I don't know how to get what I want.
Anyone know how to get what I am wanting?
EDIT: Oh yeah I know I have to play with the bump setting a bit. My VSS settings aren't  where I want them yet.
bagginsbill ( ) posted Sat, 05 December 2009 at 7:53 AM
Use the Albino shader I posted, and plug your scar map into the Albino strength parameter.
dasquid ( ) posted Sat, 05 December 2009 at 5:41 PM
Quote - Use the Albino shader I posted, and plug your scar map into the Albino strength parameter.
Would that allow me to get the SSS along with the scars standing out? I may need help with that. At this point I have no clue where to start.
dasquid ( ) posted Sun, 06 December 2009 at 5:14 PM
Quote - > Quote - Use the Albino shader I posted, and plug your scar map into the Albino strength parameter.
Ok answered my own question about the SSS but still trying to figure out how to get the scar map plugged in properly.
