Wed, Jan 8, 7:04 AM CST
Subject: Character INJ does not respond V4.2
Eagle_hawke ( ) posted Sun, 13 December 2009 at 8:40 PM · edited Wed, 04 December 2024 at 9:42 AM
 Ok does anyone know why a character INJ pose wouldn't work? The req are V4.2 and Morphs++, both of which I have. I'm running Poser 8 and the Character is RDNA Zariah. It gives no errors nor does it try to locate missing files it acts like it's loading but nothing happens.
I have had this happen with a few other models so I'm not convinced this is an error with the Character as much as some glitch with V4.2 or Poser. Any Ideas?
Medzinatar ( ) posted Sun, 13 December 2009 at 10:04 PM
For the head, it only injects one custom morph under community, RMZarH3, with value set to 1.0
Do have morph present with that value?
Eagle_hawke ( ) posted Sun, 13 December 2009 at 10:33 PM
 no there's no RMZarh3 present. I have located the pz file in "RuntimeLibrariesRMMorphsRMZariah" where it should be, but it's just not loading.
Medzinatar ( ) posted Sun, 13 December 2009 at 11:20 PM
Head morph is loaded into last of community channels, PBMCC_50
If for some reason, you don't have that channel in model, it won't take.
For test, load V4 and morphs++ and save temporary figure back to library under some name like "test".  Open in "test.cr2" in text editor and search for string PBMCC_50, or maybe just PBMCC so you can see how many you actually have.
lesbentley ( ) posted Mon, 14 December 2009 at 5:35 AM
Try running the "Update Victoria 4.2 Base", you should find this on your desktop. Many morph packs require you to run the updater after installing the morph pack.
