Sat, Jan 11, 7:34 AM CST
Subject: [HELP]Terrain painting
Sharp177 ( ) posted Fri, 25 December 2009 at 5:01 PM · edited Tue, 07 January 2025 at 10:35 PM
question on painting in the Terrain Editor in Vue 8.
How do I carve?
I can see raise in Editor,  and I see in Vue 6 a carve button existed but now there is nothing.
Kinda baffled on this one.
Thanks in advance.
Rutra ( ) posted Fri, 25 December 2009 at 5:12 PM
Tick the 'invert' checkbox. It inverts whatever function is selected.
Crowning ( ) posted Fri, 25 December 2009 at 5:17 PM
Quote - question on painting in the Terrain Editor in Vue 8.
How do I carve?
Thanks in advance.
Just select the 'Invert' checkbox of the 'Paint' tab in the terrain editor.
Philywebrider ( ) posted Sun, 27 December 2009 at 8:55 AM
It doesn't seem to work. Effects work, but reshaping doesn't
sangelico ( ) posted Sun, 27 December 2009 at 9:40 AM
Do you by any chance have a Wacom and a regular mouse hooked up to your computer? I found I had to remove my regular (usb) mouse and only use my Wacom to get sculpting working properly.
Philywebrider ( ) posted Sun, 27 December 2009 at 10:49 AM
I'm using a Wacom tablet.Everything in the effects tab works. Nothing in the Paint tab works, ( includeing Effects ) that are under the 'Paint" tab.
Sharp177 ( ) posted Sun, 27 December 2009 at 11:30 AM
Thanks for letting me know about invert. Be nice if the V invert hotkey wasn't sticky/click on/off type setting. Ah well, can't have everything.
I'm using a Wacom Intuous 3 and the paint settings and effects settings work on my Win 7 system.
Philywebrider ( ) posted Sun, 27 December 2009 at 12:33 PM
I'm working with a PC XP system with an Intros 4
sangelico ( ) posted Sun, 27 December 2009 at 1:14 PM
Philywebrider - I had the same problem with nothing on the paint tab working. Actually the 2d brushes would work until I switched to a 3d brush, then after that neither the 2d nor 3d would work.  I have an Intuos 3 on Windows 7 64-bit. Before narrowing my problem down to a conflict with the Wacom and the gigaware usb mouse (standard mouse, nothing fancy, from Radioshack) I updated all drivers (nvidia, wacom) and Vue (I'm running build 47776).
It's a pity I couldn't solve the problem without disconnecting the usb mouse, because I liked it better than the wacom mouse - it's more responsive. I did submit a ticket to eon, but I've not heard anything back.
Really it appears it was more of a driver/hardware problem on my setup than a Vue problem anyway. It doesn't seem to be a common problem. You're the first person I've some across with something similar. Good luck on getting 3d sculpting to work, it's a nice feature.
Philywebrider ( ) posted Sun, 27 December 2009 at 10:11 PM
Here's my paint screen, can anyone see anything wrong?
