Sun, Jan 12, 12:17 PM CST
Subject: How to setup and rigging rope ?
davedoo ( ) posted Wed, 30 December 2009 at 10:25 PM · edited Sun, 12 January 2025 at 12:08 PM
Hi,
Anyone has any advise on rigging a rope ?
Where can I find tutorials in the net ?
Thanks
markschum ( ) posted Wed, 30 December 2009 at 11:21 PM
Ropes are very easy but you need a reasonable amount of geometry  for the bones to work.
create your rope object along one axis, then in the setup room add a series of bones from one end to the other. Use autogroup to allocate polygons to the bones.  Exit setup room and you are basically done .
There is a easypose rope in freestuff if you want to see an example.
PhilC ( ) posted Thu, 31 December 2009 at 3:58 AM
You may find this Poser plug in of interest.
All Tied Up
It makes ropes and chains with Easy Pose controls built in.
davedoo ( ) posted Thu, 31 December 2009 at 7:22 AM
Thanks to M**arkschum and PhilC for the reply.
Is Easypose a utility or plugin ? Where can I find it ?
davedoo ( ) posted Thu, 31 December 2009 at 8:59 AM
Hi, Can Easypose and All Teied Up create variuos irregular shapes as shown in the attached image? From a straighten rope to irregular shapes? Thanks
markschum ( ) posted Thu, 31 December 2009 at 9:23 AM
EasyPose is a brand name for Posers ERC . You can manually add it to any figure, its basically a master dial that can control slaves in the various body parts. Irregular shapes would be a mix of different values in the slave dials and you would get the same irregular shape each time.
EasyPose and AllTiedUp are utilities that make ading the master and slave dials much easier. Worth the expense if you plan on doing much wirh it.
There are also a few python scripts that allow you to select multiple body parts , and apply a bend,twist to all of them. Its a sort of external easypose program.
davedoo ( ) posted Thu, 31 December 2009 at 11:01 AM
Thanks again Markschum.
So, what are the names of the scripts and where can I find it ?
markschum ( ) posted Thu, 31 December 2009 at 11:21 AM
Freestuff here
**Chain Pose 1.03 by Dimension3d  in Poser > utilities on page 4
This does not rig or apply easypose. It runs on an existing figure and allows you to apply bend or twist etc to a group of body parts.
davedoo ( ) posted Thu, 31 December 2009 at 9:41 PM
Thanks Markschum. I'm going to try it out.
