Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 6:55 am)
Attached Link: Morph Tutorial compliments of Dr Geep Stodios
*(click the image to view full size) (click the link above the image and scroll down to view the complete tut)*Dear Brick Wall, :lol:
You may find some help in the tutorial about morphs.
In the meantime, make sure you UNcheck "Centered" when you import .
Centering places the center of the imported object in the center of the Poser studio and will bury it halfway in the GROUND. ... ;=[
cheers,
dr (bob) geep
P.S. Please SEE PAGE 10 in the tut !
cheers,
dr geep ... :o]
edited 10/5/2019
Attached Link: http://www.drgeep.com/p4/mt/mt.htm
... one more time ... ;=]Remember ... "With Poser, all things are possible, and poseable!"
cheers,
dr geep ... :o]
edited 10/5/2019
You need to create a base line in your modeling program to guage scale and position against. The easiest way to do this is uncompress the obj files in Poser, then make a copy of a figure obj from the Runtime:Geometries and import that into your modeling program as your base line.
Say "PrestoChango!" :lol:
Hi Geep.
Synchronicity rears it's extremely strange head!!
I was just reading your Wings3D tutorial and just checked back to see if there was a reply.
SPOOKY!!!
I have tried to import without the centred setting but............hang on!
I just thought I'd try it again and it it has actually imported above the ground plane this time, only problem is it is tiny!
Me and Poser are going to have a serious falling out soon.
How weird, I thought that I'd done that before. I wonder if............no, still doesn't work.
Tried to use it as a target again and it still pulls the body part down.
Could my scale be wrong? The tutorial said to scale up by 1000 to work on it and then 'scale the group back down by .001'.
This seems a bit ambiguous, is it scale back to 0.001 or scale it down by 0.001 which will be 0.999 because it is importing so small?
Hi Dark Edge,
I did try that option but according to the tutorial apparently the Obj import on C4D messes with the geometry somehow and you end up with a mess. I tried it and ended up with something akin to a hedgehog having a bad hair day when I injected the MT to the figure.
Looks like you have to open the figure in Poser and export as 3DS to preserve the geometry.
I think I'll get a copy of Wings3D and try that, it may be that C4D just too finniky for greating morphs. I only want to try some simple morphs anyway so I dont need to have a mega program to do that.
Thanks for your reply, I'll post any success (or hospital bills!).
If you are using C4D, look into Riptide, it has a lot more functions than C4D's base OBJ converter. I use it daily, great utility.
http://skinprops.com/riptide.php
Ok, sucess!!!!!!!
It is obviously C4D's obj export module that is the problem.
Just tried Riptide and everything worked hunkydory (hey thats Bowie isn't it!).
Thanks to everyone for their time and advice, you guys ROCK!
I'm going to try Wings3D as well just to add another string to my rendering bow.
I really must start posting my renders here so you guys can see the results.
Once again thanks for taking time out of your day to help a befuddled and irate morphing newbie.
I'm off to morph everything and anything (watchout Tibbles, your next!) and dab my forehead with copious amounts of TCP.
Cheers guys.
Hi All,
I have decided to dip my toe into the creating my own morphs for poser figures and have come up against a brick wall.
My problem is that although I can create the morphed obj with no problem at all, everytime I import it into Poser to check that it is in the correct position on the figure it imports at a position that is bisected by the ground plane (This is also true for any other obj file I try to import.) and so if I use the obj as a morph target the body part is dragged down to the ground plane. The actual morph seems to work but only when the body part is at this position.
Now as you can imagine this is rather frustrating, especially as I see the wonderful morphs that are produced by members of this community and I'd rather not start the New Year with a large lump on my forehead due to constantly banging it against the wall.
I am using C4D R10 to create the morphs and following Shanna's tutorial
http://artzone.daz3d.com/wiki/doku.php/pub/tutorials/models/models-gen34
and Poser 6 (although I can get access to Poser 7 on a friends computer) to try out the morph.
If anyone can help you will be saving an poor soul from permanent disfigurement (or would that be morphing?) by a large and rather solid brick wall.
