Wed, Jan 8, 4:04 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 04 8:20 pm)
Carrara Free Stuff here.
Subject: Carrara7 UI issue
ninhalo5 ( ) posted Sun, 10 January 2010 at 8:51 AM · edited Tue, 07 January 2025 at 3:29 AM
I posted this over at DAZ but no one answered, maybe someone here knows:
Hi, I have a problem with Carrara 7 I'm wondering if anyone else has had this problem and if so what did they do to fix it.
Whats happening is I'll open carrara to a empty scene (any scene really).
and anything that is selectable whether it's from the file/edit etc.. pull down menus, the browser, properties panel or whatever I get a grab hand icon instead of the regular pointer.
The hand icon will not allow me to select anything, if I'm trying to use something from a pull down menu such as exit,save or even create a sphere those windows will just close.
Now if I have Carrara open and the hand icon appears I can leave Carrera sit for 15 minutes and I'll get the pointer back for a couple clicks then it will disappear again.
I am thinking this might be a hardware problem possibly a setting that can be changed?
I have no problems running any other programs such as Studio, Maya, Poser etc..
Im using Vista home x64 though I doubt that would be an issue, with an i7 core processor. all my other x32 programs run just fine even Maya 8 which is not even designed for Vista Smile
Any ideas?
Thanks
on another note does anyone know where to find some good tutorials for Carrara 7?  most of the tuts I find are for 6 and below and it seems they don't work in 7. either that or the way to access the the properties are different. some items I can not get a property box to make my adjustments.
Thanks
sparrownightmare ( ) posted Sun, 10 January 2010 at 9:15 AM
Have you tried uninstalling and reinstalling C7?
ninhalo5 ( ) posted Sun, 10 January 2010 at 9:16 AM
no I just bought it and installed it for the first time 2 days ago, I'll give it a try maybe it got corrupted somehow
sparrownightmare ( ) posted Sun, 10 January 2010 at 9:23 AM
If you had any previous versions of Carrara on the system, you may want to zap them before you install 7.  Just in case.
Antaran ( ) posted Sun, 10 January 2010 at 9:35 AM
I get that problem on occasion too. Instead of leaving it to sit for 15 minutes, I close Carrara and work on the computer, in about half an hour if I open Carrara it might be back to normal, if not, I restart the computer and then it definitely is back to normal. At least so far rebooting always fixed it. I use XP 64, though.
I also noticed that this phenomenon is more likely to happen when I watch streaming video while Carrara is actively running (doing some computations, or I go back and forth while the streaming is on). But this could just be a coincidence, or it could be the particularity of the problem on my hardware.
ninhalo5 ( ) posted Sun, 10 January 2010 at 11:12 AM
Hmm interesting, in fact I've had video up every time this has happened trying to look at tutorials, youtube or something. I wonder what would cause such a thing. I'll test that out with videos and submit a bug report if that is the case.
faba ( ) posted Sun, 10 January 2010 at 11:21 AM
Although "the hand" come back from time to time, hitting the space bar always helped me to remove it and let me work on.
alexcoppo ( ) posted Sun, 10 January 2010 at 3:26 PM
It is a well known bug connected with watching videos. Use the space bar workaround.
GIMP 2.7.4, Inkscape 0.48, Genetica 3.6 Basic, FilterForge 3 Professional, Blender 2.61, SketchUp 8, PoserPro 2012, Vue 10 Infinite, World Machine 2.3, GeoControl 2
ninhalo5 ( ) posted Sun, 10 January 2010 at 6:55 PM
Cool I'll give it a try
Thanks everyone
illkirch ( ) posted Mon, 11 January 2010 at 2:09 AM
Same here after watching videos. And a similar problem with Poser. I just reboot the computer.
