I've run into this problem as well, and the usual cause is that you have the lip section painted just a bit to wide of the mesh. Quagnon has a great skin painting tutorial online, I highly recommend it to anyone attempting a first-time texture painting. I followed it, and had my first texture done in relatively little time, with no major flaws. Look in the Tutorials section here on Renderosity for the link.
If you're using a bump map that isn't made from your texture, you also want to adjust it to make sure that the placement of features are the same on both, or you get ridges like that. By the way, you may need to adjust the focal length on the camera, unless you're after a fisheye lens look - Poser's default is set WAY too low. I use at least 100.
